Zum Hauptinhalt wechseln
Nvidia Shield Tablet Rear Case Replacement
Was du brauchst
  1. Nvidia Shield Tablet Rear Case Replacement, Rear Case: Schritt 1, Bild 1 von 2 Nvidia Shield Tablet Rear Case Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • First, remove the stylus from your tablet.
  2. Nvidia Shield Tablet Rear Case Replacement: Schritt 2, Bild 1 von 3 Nvidia Shield Tablet Rear Case Replacement: Schritt 2, Bild 2 von 3 Nvidia Shield Tablet Rear Case Replacement: Schritt 2, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Rear Case Replacement: Schritt 3, Bild 1 von 2 Nvidia Shield Tablet Rear Case Replacement: Schritt 3, Bild 2 von 2
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Molly Bauer
1.442 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 2-2, Blackwell Fall 2015 Mitglied von USF Tampa, Team 2-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G2
3 Mitglieder
11 Anleitungen geschrieben
Ein Kommentar
I snapped the cable of the dabbler on the rear case coz i didnt know there was one!
Anyone knows where can i get a new one?
damjannedelkovski - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 16
Insgesamt: 3,411
