Zum Hauptinhalt wechseln
Nvidia Shield Tablet Speaker Replacement
Was du brauchst
  1. Nvidia Shield Tablet Speaker Replacement, Rear Case: Schritt 1, Bild 1 von 2 Nvidia Shield Tablet Speaker Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • First, remove the stylus from your tablet.
  2. Nvidia Shield Tablet Speaker Replacement: Schritt 2, Bild 1 von 3 Nvidia Shield Tablet Speaker Replacement: Schritt 2, Bild 2 von 3 Nvidia Shield Tablet Speaker Replacement: Schritt 2, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Speaker Replacement: Schritt 3, Bild 1 von 2 Nvidia Shield Tablet Speaker Replacement: Schritt 3, Bild 2 von 2
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
  4. Nvidia Shield Tablet Speaker Replacement, Speaker: Schritt 4, Bild 1 von 1
    • Orient your tablet so that the top of the tablet is furthest away from you.
    • Locate the top speaker, a black semi-rectangular piece on the top right side of the tablet.
  5. Nvidia Shield Tablet Speaker Replacement: Schritt 5, Bild 1 von 1
    • Remove the two 3.0 mm Phillips #00 screws securing the speaker.
  6. Nvidia Shield Tablet Speaker Replacement: Schritt 6, Bild 1 von 3 Nvidia Shield Tablet Speaker Replacement: Schritt 6, Bild 2 von 3 Nvidia Shield Tablet Speaker Replacement: Schritt 6, Bild 3 von 3
    • Gently pry the speaker up with the flat end of a spudger.
    • Use a plastic opening tool to peel up the tape covering the speaker wire.
  7. Nvidia Shield Tablet Speaker Replacement: Schritt 7, Bild 1 von 2 Nvidia Shield Tablet Speaker Replacement: Schritt 7, Bild 2 von 2
    $7.95
    Kaufen
    • Next, with a gentle but firm grip, pull the audio input ribbon with the precision tweezers.
    • Finally, unplug the power source from your speaker using the precision tweezers.
    • Make sure you are using your anti-static wrist strap.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Molly Bauer
1.424 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 2-2, Blackwell Fall 2015 Mitglied von USF Tampa, Team 2-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G2
3 Mitglieder
11 Anleitungen geschrieben
Ein Kommentar
This didn't work
Riley Schork - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 2,605
