Zum Hauptinhalt wechseln
OLPC XO-1.5 Power Button Replacement
Was du brauchst
  1. OLPC XO-1.5 Power Button Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the laptop upside down with the handle away from you.
  2. OLPC XO-1.5 Power Button Replacement: Schritt 2, Bild 1 von 1
    • Slide the tabs out, towards the green edges, to show the open lock symbol.
    • The right tab will stay in place, but the left tab must be held in position while you remove the battery.
  3. OLPC XO-1.5 Power Button Replacement: Schritt 3, Bild 1 von 3 OLPC XO-1.5 Power Button Replacement: Schritt 3, Bild 2 von 3 OLPC XO-1.5 Power Button Replacement: Schritt 3, Bild 3 von 3
    • Lift the middle of the battery to remove it.
  4. OLPC XO-1.5 Power Button Replacement, Screen: Schritt 4, Bild 1 von 3 OLPC XO-1.5 Power Button Replacement, Screen: Schritt 4, Bild 2 von 3 OLPC XO-1.5 Power Button Replacement, Screen: Schritt 4, Bild 3 von 3
    • Turn the laptop so it is resting on its bottom.
    • Open the laptop by rotating the green wings on the side up, then lifting the top half of the laptop.
    • Rotate the top half of the laptop about 90 degrees.
  5. OLPC XO-1.5 Power Button Replacement: Schritt 5, Bild 1 von 2 OLPC XO-1.5 Power Button Replacement: Schritt 5, Bild 2 von 2
    • Turn the laptop upside down, so you can see the screws on the bottom of the top half.
    • Remove the two 4mm screws with a Phillips #1 screwdriver.
    • Rotate the top half 180 degrees.
  6. OLPC XO-1.5 Power Button Replacement: Schritt 6, Bild 1 von 1
    • Rotate the top of the laptop 90 degrees, so that it is facing you again.
    • Slide the green pieces off the device. They should come off easily.
  7. OLPC XO-1.5 Power Button Replacement: Schritt 7, Bild 1 von 3 OLPC XO-1.5 Power Button Replacement: Schritt 7, Bild 2 von 3 OLPC XO-1.5 Power Button Replacement: Schritt 7, Bild 3 von 3
    • Pull down on the white screen cover. It does not require much force.
    • Remove the screen cover.
    • The game pad on the left sometimes falls during this step.
  8. OLPC XO-1.5 Power Button Replacement: Schritt 8, Bild 1 von 2 OLPC XO-1.5 Power Button Replacement: Schritt 8, Bild 2 von 2
    • Unscrew the four 7.62mm Phillips #1 screws on either side of the screen.
    • The screen is still connected by ribbon cables. You can damage the cables if you remove the screen before disconnecting the cables.
    • Move the screen down a little to expose the ribbon cables.
  9. OLPC XO-1.5 Power Button Replacement: Schritt 9, Bild 1 von 3 OLPC XO-1.5 Power Button Replacement: Schritt 9, Bild 2 von 3 OLPC XO-1.5 Power Button Replacement: Schritt 9, Bild 3 von 3
    • Flip up the tab right under the middle top of the screen.
    • Pull the black ribbon cable out of the socket.
  10. OLPC XO-1.5 Power Button Replacement: Schritt 10, Bild 1 von 2 OLPC XO-1.5 Power Button Replacement: Schritt 10, Bild 2 von 2
    • Flip up the smaller tab under the left side of the screen.
    • Remove the small cable to separate the screen from the rest of the laptop.
    • Gently remove the screen.
  11. OLPC XO-1.5 Power Button Replacement, Wireless Card: Schritt 11, Bild 1 von 1
    • Remove the four 4mm Phillips #1 screws that hold the top cover to the case.
  12. OLPC XO-1.5 Power Button Replacement: Schritt 12, Bild 1 von 2 OLPC XO-1.5 Power Button Replacement: Schritt 12, Bild 2 von 2
    • Close the lid and rotate the device 180°.
    • Press firmly on the top two corners of the outside cover. Then slide it down, away from the antennas.
  13. OLPC XO-1.5 Power Button Replacement: Schritt 13, Bild 1 von 2 OLPC XO-1.5 Power Button Replacement: Schritt 13, Bild 2 von 2
    • Remove the five 4mm Phillips #1 screws securing the EMI shield to the motherboard.
    • Gently lift up and remove the EMI shield.
  14. OLPC XO-1.5 Power Button Replacement: Schritt 14, Bild 1 von 1
    • Gently remove the two antenna cables by lightly pulling the cable connectors up.
  15. OLPC XO-1.5 Power Button Replacement: Schritt 15, Bild 1 von 2 OLPC XO-1.5 Power Button Replacement: Schritt 15, Bild 2 von 2
    • Remove the two 5mm Phillips #1 screws holding the wireless card to the motherboard.
    • The wireless card will pop up at an angle.
  16. OLPC XO-1.5 Power Button Replacement: Schritt 16, Bild 1 von 1
    • Remove the wireless card by gently lifting it out of the socket.
  17. OLPC XO-1.5 Power Button Replacement, Motherboard: Schritt 17, Bild 1 von 3 OLPC XO-1.5 Power Button Replacement, Motherboard: Schritt 17, Bild 2 von 3 OLPC XO-1.5 Power Button Replacement, Motherboard: Schritt 17, Bild 3 von 3
    • Disconnect the five cables that connect the motherboard to the case by pulling them straight out of their sockets.
    • The motherboard is still attached to the case by a microphone cable. Do not remove the motherboard or you will damage the cable.
  18. OLPC XO-1.5 Power Button Replacement: Schritt 18, Bild 1 von 1
    • Rotate the device 180° and open the lid.
    • Disconnect the microphone cable by pulling its connector straight out of its socket on the motherboard.
  19. OLPC XO-1.5 Power Button Replacement: Schritt 19, Bild 1 von 3 OLPC XO-1.5 Power Button Replacement: Schritt 19, Bild 2 von 3 OLPC XO-1.5 Power Button Replacement: Schritt 19, Bild 3 von 3
    • Lift the left edge of the motherboard and remove it from the case.
    • Make sure that the microphone and headphone jack don't catch on the case as you are removing the motherboard.
  20. OLPC XO-1.5 Power Button Replacement, Power Button: Schritt 20, Bild 1 von 3 OLPC XO-1.5 Power Button Replacement, Power Button: Schritt 20, Bild 2 von 3 OLPC XO-1.5 Power Button Replacement, Power Button: Schritt 20, Bild 3 von 3
    • Push the four power button retaining clips through the bottom of the case with the tip of a screwdriver.
    • Open the lid, rotate it 180° degrees, and close it again.
    • Be careful not to lose the small spring that sits inside the power button.
Abschluss
Wei Xia
518 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 3-28, Amido Winter 2013 Mitglied von Cal Poly, Team 3-28, Amido Winter 2013
CPSU-AMIDO-W13S3G28
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 303
