Einleitung
How to replace the two antenna on the OLPC XO-4 Touch.
Was du brauchst
Pull the lock tabs towards the green outer edges of the laptop.
Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
Rotate the screen 180° and remove the other two screws.
Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
Repeat the step above for the panel on the other side.
Gently lift up the lower part of the frame and pull it down to free the screen frame.
Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
For each ribbon cable, lift up the black connector and gently pull the ribbon cables out by the plastic tabs.
Rotate the top half of the laptop so that the back cover is facing you.
Pull up the tabs on the lower part of the back cover and pull it down and away from the antennas.
Remove the back cover by gently lifting it off of the laptop.
Gently unplug the two connectors by pulling them away from the motherboard.
Unscrew the four black 4mm Phillips #1 screws holding the metal cover on.
Remove the metal cover by gently lifting it out of the laptop.
Flip the top part of the laptop over so that you are looking at the front.
Unscrew the two 12.7mm Phillips #1 screws on each antenna ear clamp.
Remove the two outer clamps.
Remove the antenna wires from the black tabs.
On the front side of the laptop, carefully pull the wire through the hole and out.
Remove the antenna from the laptop.
Eine weitere Person hat diese Anleitung absolviert.
