Einleitung
Use this guide to replace the rear case on your Oppo N1.
Was du brauchst
Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
The rear case should then come free.
10 weitere Personen haben diese Anleitung absolviert.
