Zum Hauptinhalt wechseln
ORFELD EV-660-S222 Battery LED Board Replacement
Was du brauchst
  1. ORFELD EV-660-S222 Battery LED Board Replacement, Battery LED Board: Schritt 1, Bild 1 von 1
    • Separate the dust cover and the motor from the vacuum body by pressing the eject button.
  2. ORFELD EV-660-S222 Battery LED Board Replacement: Schritt 2, Bild 1 von 2 ORFELD EV-660-S222 Battery LED Board Replacement: Schritt 2, Bild 2 von 2
    • Place the vacuum on its side, with the screws facing towards you.
    • Remove the 11.5 mm screws using a Phillips #1 screwdriver.
  3. ORFELD EV-660-S222 Battery LED Board Replacement: Schritt 3, Bild 1 von 2 ORFELD EV-660-S222 Battery LED Board Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Using tweezers, remove the sticker connecting the two halves.
    • Use the opening pick to gently separate the top half and the bottom half of the vacuum.
    • Press the blue buttons near the sides of the battery LEDs to remove the top half.
  4. ORFELD EV-660-S222 Battery LED Board Replacement: Schritt 4, Bild 1 von 2 ORFELD EV-660-S222 Battery LED Board Replacement: Schritt 4, Bild 2 von 2
    • Slide out the charging port.
  5. ORFELD EV-660-S222 Battery LED Board Replacement: Schritt 5, Bild 1 von 1
    • Lift the battery slightly to reveal the pin connectors.
    • Gently disconnect the six-pin connector that connects to the power button and battery LEDs.
  6. ORFELD EV-660-S222 Battery LED Board Replacement: Schritt 6, Bild 1 von 3 ORFELD EV-660-S222 Battery LED Board Replacement: Schritt 6, Bild 2 von 3 ORFELD EV-660-S222 Battery LED Board Replacement: Schritt 6, Bild 3 von 3
    • Slide out the battery LEDs from the compartment.
    • Remove the plastic LED cover from the LED board.
  7. ORFELD EV-660-S222 Battery LED Board Replacement: Schritt 7, Bild 1 von 1
    • Desolder the LED board from the wires.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 30
Insgesamt: 888
