Einleitung
If your ORFELD EV-660 has stopped charging entirely or rapidly starts and stops charging, your charging port is most likely the culprit.
Was du brauchst
Separate the dust cover and the motor from the vacuum body by pressing the eject button.
Place the vacuum on its side, with the screws facing towards you.
Remove the 11.5 mm screws using a Phillips #1 screwdriver.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using tweezers, remove the sticker connecting the two halves.
Use the opening pick to gently separate the top half and the bottom half of the vacuum.
Press the blue buttons near the sides of the battery LEDs to remove the top half.
Lift the battery slightly to reveal the pin connectors.
Gently remove the four-pin connector connecting the charging port.
