Einleitung
The purpose of this guide is to provide information on replacing the buttons on your Oculus Rift CV1 remote. You can learn more about the Oculus Rift CV1 on the device page. You will need a Phillips #000 screwdriver for this replacement. Ensure buttons are cleaned with an electronics safe cleaner before reassembly to prevent the buttons from sticking.
Was du brauchst
Push down on the tab under the battery.
Firmly slide the battery away from you. The battery should unlatch from its previous position.
Once the battery is removed, release the tab.
Remove the four 4mm Phillips #000 screws from the back of the remote.
