Einleitung
If the device is not tracking motion properly this could be due to a broken camera motherboard. Common causes for motherboard failure include being exposed to static shock, overheating, or component failure.
Was du brauchst
Remove the cover plate from the front face of the camera using the iFixit Opening Pick.
Remove the four 3/16" Phillips #000 from the four corners of the motherboard.
Remove the two 1/4" Phillips #0 screws shown to release the motherboard from the enclosure.
Eine weitere Person hat diese Anleitung absolviert.
