Zum Hauptinhalt wechseln
Oculus Rift Development Kit 2 Headset Motherboard Replacement
Was du brauchst
  1. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: Schritt 1, Bild 1 von 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: Schritt 1, Bild 2 von 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: Schritt 1, Bild 3 von 3
    • Remove front cover plate.
    • Unplug the USB and HDMI cables from the Oculus Rift DK2.
  2. Oculus Rift Development Kit 2 Headset Motherboard Replacement: Schritt 2, Bild 1 von 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: Schritt 2, Bild 2 von 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Remove the four 3/8" Phillips #0 screws from the inner portion of the headset.
  3. Oculus Rift Development Kit 2 Headset Motherboard Replacement: Schritt 3, Bild 1 von 2 Oculus Rift Development Kit 2 Headset Motherboard Replacement: Schritt 3, Bild 2 von 2
    • With the screws removed, gently pull the headband frame apart from the headset.
  4. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Remove Lens: Schritt 4, Bild 1 von 2 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Remove Lens: Schritt 4, Bild 2 von 2
    • With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead.
  5. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Headset Motherboard: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Using tweezers, carefully lift the four rubber plugs as shown. They are a bit snug and you may need to jiggle them free with the tweezers.
  6. Oculus Rift Development Kit 2 Headset Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the four 3/8" screws attaching the eyewear enclosure to the front casing.
    • Read the next step before removing the faceplate!
  7. Oculus Rift Development Kit 2 Headset Motherboard Replacement: Schritt 7, Bild 1 von 2 Oculus Rift Development Kit 2 Headset Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Carefully separate the faceplate and the cover. Gently rest the cover plate on top of the faceplate as shown in the pictures.
    • Do not use excessive force when separating these two pieces. There is a delicate ribbon cable connected to each.
  8. Oculus Rift Development Kit 2 Headset Motherboard Replacement: Schritt 8, Bild 1 von 2 Oculus Rift Development Kit 2 Headset Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Gently pull out the small side tabs on the ribbon cable connector as shown to release the cable.
    • Push the tabs away from you, with the headset oriented as pictured. Carefully slide the ribbon cable out.
    • The headset should now be two separate pieces.
  9. Oculus Rift Development Kit 2 Headset Motherboard Replacement: Schritt 9, Bild 1 von 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: Schritt 9, Bild 2 von 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Unscrew the three 1/4" Phillips #00 screws as pictured and use the tweezers to lift them out.
  10. Oculus Rift Development Kit 2 Headset Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Lift the tape and gently pry up the video data ribbon cable using the plastic opening tool as shown.
  11. Oculus Rift Development Kit 2 Headset Motherboard Replacement: Schritt 11, Bild 1 von 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: Schritt 11, Bild 2 von 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: Schritt 11, Bild 3 von 3
    • Gently pry back the motherboard clips to release the motherboard. The motherboard should now lift free.
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
Adam
661 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 18-5, Maness Winter 2015 Mitglied von Cal Poly, Team 18-5, Maness Winter 2015
CPSU-MANESS-W15S18G5
4 Mitglieder
6 Anleitungen geschrieben
1 Kommentar zur Anleitung
hi.
you know where possible buy the new motherboard?
Szatmari Attila - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 16
Insgesamt: 2,645
