Einleitung
In this guide, you will be learned how to swap out your Oculus Touch batteries if you give your headset to a friend and someone else, you do need to know how to replace batteries, if you want to continue playing, You only need an Opening tool and that’s all!
Was du brauchst
Slide down the cover on the left or right side of your chosen controller.
After opening, push forward the battery and lift it up while holding the ring on the controller with your other hand.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
