Einleitung
The X7R Marauder from Olight is a great flashlight. Unfortunately, the batteries are permanently installed and, according to the manufacturer, cannot be replaced by the user.
If your batteries go bad after the warranty has expired, you can use the following steps to replace the batteries in your Olight 7XR flashlight.
Was du brauchst
The three screws on the side can be loosened by a 0.9mm Allen key.
The cover can then be removed.
The next four screws are encapsulated in silicone. A Phillips screwdriver (PH1) can simply be pushed through the silicone and the screws can be loosened.
The outer ring including the plastic cover can then be removed.
The electronics are now visible. Take out the circuit board by removing the two Phillips #1 screws.
After loosening the screws, the circuit board can be carefully turned over in the direction of the cables.
There is a plastic cover under the circuit board. This can be removed using the iFixit spudger.
The 18650 battery cells are now visible and can be removed.
Reverse the steps to reassemble your device.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Andrew S hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
2 Kommentare
what size allen key?
what size are the batteries?
The allen key size is H0.9mm
The battery size is 18650.
Andrew S -
