Zum Hauptinhalt wechseln
Olympic Fencing Foil Handguard Replacement
Was du brauchst
  1. Olympic Fencing Foil Handguard Replacement, Olympic Fencing Foil Handguard: Schritt 1, Bild 1 von 3 Olympic Fencing Foil Handguard Replacement, Olympic Fencing Foil Handguard: Schritt 1, Bild 2 von 3 Olympic Fencing Foil Handguard Replacement, Olympic Fencing Foil Handguard: Schritt 1, Bild 3 von 3
    • Remove the nut securing the handle with the 1 x 6 mm hex key.
  2. Olympic Fencing Foil Handguard Replacement: Schritt 2, Bild 1 von 2 Olympic Fencing Foil Handguard Replacement: Schritt 2, Bild 2 von 2
    • Remove the grip and pad.
  3. Olympic Fencing Foil Handguard Replacement: Schritt 3, Bild 1 von 2 Olympic Fencing Foil Handguard Replacement: Schritt 3, Bild 2 von 2
    • Use pliers to hold the hexnut still while using a flathead screwdriver to loosen the socket holding the wire.
    • Do not completely remove the socket from the socket holder.
  4. Olympic Fencing Foil Handguard Replacement: Schritt 4, Bild 1 von 3 Olympic Fencing Foil Handguard Replacement: Schritt 4, Bild 2 von 3 Olympic Fencing Foil Handguard Replacement: Schritt 4, Bild 3 von 3
    • Unwrap the wire from the socket.
    • Be gentle unwrapping the wire; excessive twisting may snap the wire.
  5. Olympic Fencing Foil Handguard Replacement: Schritt 5, Bild 1 von 3 Olympic Fencing Foil Handguard Replacement: Schritt 5, Bild 2 von 3 Olympic Fencing Foil Handguard Replacement: Schritt 5, Bild 3 von 3
    • Take the wire out under the socket holder's hole.
    • If there is tape holding down the wire, remove it.
  6. Olympic Fencing Foil Handguard Replacement: Schritt 6, Bild 1 von 3 Olympic Fencing Foil Handguard Replacement: Schritt 6, Bild 2 von 3 Olympic Fencing Foil Handguard Replacement: Schritt 6, Bild 3 von 3
    • Remove the socket holder.
    • Remove the old handguard.
    • Get your new handguard ready.
  7. Olympic Fencing Foil Handguard Replacement: Schritt 7, Bild 1 von 2 Olympic Fencing Foil Handguard Replacement: Schritt 7, Bild 2 von 2
    • Thread the wire through the new handguard.
    • Insert the new handguard on the foil.
  8. Olympic Fencing Foil Handguard Replacement: Schritt 8, Bild 1 von 3 Olympic Fencing Foil Handguard Replacement: Schritt 8, Bild 2 von 3 Olympic Fencing Foil Handguard Replacement: Schritt 8, Bild 3 von 3
    • Thread the wire through the large sockey holder hole.
    • Insert the sockey holder back onto the foil.
    • Thread the wire through and under the small hole of the socket holder, right next to the sockets.
  9. Olympic Fencing Foil Handguard Replacement: Schritt 9, Bild 1 von 3 Olympic Fencing Foil Handguard Replacement: Schritt 9, Bild 2 von 3 Olympic Fencing Foil Handguard Replacement: Schritt 9, Bild 3 von 3
    • Wrap the exposed part of the wire around the socket.
    • Using a plier to hold the hexnut, use a flathead screwdriver to tighten the socket.
  10. Olympic Fencing Foil Handguard Replacement: Schritt 10, Bild 1 von 2 Olympic Fencing Foil Handguard Replacement: Schritt 10, Bild 2 von 2
    • Insert the pad.
    • Insert the grip.
    • When inserting the grip, make sure that the grip is not crushing the wire.
  11. Olympic Fencing Foil Handguard Replacement: Schritt 11, Bild 1 von 3 Olympic Fencing Foil Handguard Replacement: Schritt 11, Bild 2 von 3 Olympic Fencing Foil Handguard Replacement: Schritt 11, Bild 3 von 3
    • Insert and tighten the hexnut.
  12. Olympic Fencing Foil Handguard Replacement: Schritt 12, Bild 1 von 1
    • Make sure that the foil does not feel loose.
Ziellinie
Chuwei Yuan
205 Reputation
1 Anleitung geschrieben
UC Davis, Team 1-1, Morris Fall 2024 Mitglied von UC Davis, Team 1-1, Morris Fall 2024
UCD-MORRIS-F24S1G1
3 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 27
Insgesamt: 196
