Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Ersatzteile
Keine Ersatzteile angegeben.
  1. Locate the battery latch on the bottom of the device.
    • Locate the battery latch on the bottom of the device.
  2. Unscrew the one screw on the latch. Remove the screw.
    • Unscrew the one screw on the latch.
    • Remove the screw.
  3. Das Essential Toolkit
    Die nützlichsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  4. Remove the small black plastic piece positioned at the opening side of the battery latch.
    • Remove the small black plastic piece positioned at the opening side of the battery latch.
  5. You will now be able to lift and remove the thin metal covering from battery latch.
    • You will now be able to lift and remove the thin metal covering from battery latch.
  6. Open the latch.
    • Open the latch.
  7. Locate the screw in the center crease of the opening of the battery latch.
    • Locate the screw in the center crease of the opening of the battery latch.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Kathleen
225 Reputation
2 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 240
