Zum Hauptinhalt wechseln
Olympus 850SW Battery Replacement
Was du brauchst
  1. Olympus 850SW Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the battery compartment on the bottom panel of the camera.
  2. Olympus 850SW Battery Replacement: Schritt 2, Bild 1 von 2 Olympus 850SW Battery Replacement: Schritt 2, Bild 2 von 2
    • Using a PH00 Phillips Screwdriver, unscrew the one screw located on the latch.
  3. Olympus 850SW Battery Replacement: Schritt 3, Bild 1 von 3 Olympus 850SW Battery Replacement: Schritt 3, Bild 2 von 3 Olympus 850SW Battery Replacement: Schritt 3, Bild 3 von 3
    • Find the arrows on the compartment, remove the small black plastic piece, and release the latch.
  4. Olympus 850SW Battery Replacement: Schritt 4, Bild 1 von 1
    • Allow the latch to completely open and insert the battery, with the writing side up.
    • The battery slot is the bigger slot. The smaller slot is for the memory card.
  5. Olympus 850SW Battery Replacement: Schritt 5, Bild 1 von 1
    • Close the latch. You will hear a click when the compartment is fully closed.
  6. Olympus 850SW Battery Replacement: Schritt 6, Bild 1 von 1
    • Place the small black piece back in its' place.
  7. Olympus 850SW Battery Replacement: Schritt 7, Bild 1 von 1
    • Place the metal cover back over the closed latch, and screw the screw back in.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 778
