Zum Hauptinhalt wechseln
Olympus C-765 Status LED Replacement
Was du brauchst
  1. Olympus C-765 Status LED Replacement, Motherboard: Schritt 1, Bild 1 von 3 Olympus C-765 Status LED Replacement, Motherboard: Schritt 1, Bild 2 von 3 Olympus C-765 Status LED Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the single 4mm screw located directly to the right of the viewfinder on the back of the camera.
    • Remove the two 2mm screws from the left side panel.
    • Remove the single 3mm screw from the right side panel.
    • Remove the five 3mm screws from the bottom of the camera.
  2. Olympus C-765 Status LED Replacement: Schritt 2, Bild 1 von 2 Olympus C-765 Status LED Replacement: Schritt 2, Bild 2 von 2
    • Rock the two ribbon cables gently out of their sockets.
    • For more on disconnecting ribbon cables, look here.
    • Grasp and pull the white cable out of its clip with metal tweezers.
    • Remove the back panel completely.
  3. Olympus C-765 Status LED Replacement: Schritt 3, Bild 1 von 1
    • Peel off the black plastic sheets.
    • Use the Phillips #00 screwdriver to remove the two 3mm screws holding the motherboard in place.
  4. Olympus C-765 Status LED Replacement: Schritt 4, Bild 1 von 2 Olympus C-765 Status LED Replacement: Schritt 4, Bild 2 von 2
    • Remove the ribbon cable directly below the viewfinder.
    • Detach the white plastic clip from its socket with a pair of tweezers.
    • Disconnect the ribbon cable from the center of the board, near the central hole.
    • Disconnect the three ribbon cables from the top right of the motherboard, near the selector wheel. One is on the top of the board, and the other two are on the underside.
    • For more information on disconnecting ribbon cables, look here.
  5. Olympus C-765 Status LED Replacement: Schritt 5, Bild 1 von 1
    • Remove the single 3mm ground screw attached to the right side of the camera body using the Phillips #00 screwdriver.
  6. Olympus C-765 Status LED Replacement: Schritt 6, Bild 1 von 1
    • Use the soldering iron to desolder the connections from the motherboard.
    • For more information on desoldering, look here.
    • When soldering, avoid touching any of the other components with the soldering iron to prevent damage to the motherboard.
  7. Olympus C-765 Status LED Replacement: Schritt 7, Bild 1 von 1
    • Remove the motherboard from the camera.
  8. Olympus C-765 Status LED Replacement, Status LED: Schritt 8, Bild 1 von 2 Olympus C-765 Status LED Replacement, Status LED: Schritt 8, Bild 2 von 2
    • Remove most of the camera components from the front of the case.
    • Remove the two 3 mm screws from the right side of the casing using a Phillips #00 screwdriver.
    • Pop the flash up to get access to the two body screws underneath.
    • Remove the two 3mm screws from under the flash using a Phillips #00 screwdriver.
  9. Olympus C-765 Status LED Replacement: Schritt 9, Bild 1 von 3 Olympus C-765 Status LED Replacement: Schritt 9, Bild 2 von 3 Olympus C-765 Status LED Replacement: Schritt 9, Bild 3 von 3
    • Gently pull on the battery casing and the A/V ports to remove the connected components.
    • Remove the small ribbon cable, from the right side of the casing.
  10. Olympus C-765 Status LED Replacement: Schritt 10, Bild 1 von 2 Olympus C-765 Status LED Replacement: Schritt 10, Bild 2 von 2
    • Remove the LED circuit board.
    • Remove the single 3mm screw using a Phillips #00 screwdriver.
    • Use a pair of tweezers to remove the status LED board.
Abschluss
Mason Morgan
115 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 12-33, Maness Spring 2011 Mitglied von Cal Poly, Team 12-33, Maness Spring 2011
CPSU-MANESS-S11S12G33
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 2,274
