Einleitung
Step-by-step Instruction Guide
Olympus D590 Logic Board Replacement
Was du brauchst
Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
Remove the single screw from the battery housing using a Phillips #00 screwdriver.
To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
Remove four screws holding the motherboard to the internal housing component using a Phillips #1 screwdriver.
Use rounded tweezers to disconnect the three wiring strips from the motherboard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
