Einleitung
This guide shows how to replace a broken retainer clip (the plastic piece that covers the battery and XD card slot).
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Flip camera so you are looking at the bottom.
Unscrew all 5 base plate screws.
Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
Turn the camera so that the USB, AV and DC in/out rubber plate it facing you.
Lift the rubber plate exposing the ports beneath.
Use a flathead screwdriver or another flat opening tool to pry the faceplate from the whole device.
Orient the camera as shown, with the bottom facing up.
Open the retainer clip, by using your finger to push down and slide to the left.
The clip should pop open.
Hold the retainer clip down (without re-latching it).
Use a flathead screwdriver to start to pry out the pin holding the retainer clip's spring to the camera.
Once the pin comes out, the retainer clip, spring, and pin will no longer be attached to the rest of the camera.
