Zum Hauptinhalt wechseln
Olympus Digital Camera TG-3 Lens Ring Replacement
Was du brauchst
  1. Olympus Digital Camera TG-3 Lens Ring  Replacement, Front Case: Schritt 1, Bild 1 von 1
    • Locate the strap eyelet side of the camera and use the PH000 screwdriver to remove the two 5.3mm screws that hold the strap.
  2. Olympus Digital Camera TG-3 Lens Ring  Replacement: Schritt 2, Bild 1 von 1
    • Locate the side of the camera containing the HDMI port. Use the PH000 screwdriver to remove the 5.4mm screw located on the lower left side below the port.
  3. Olympus Digital Camera TG-3 Lens Ring  Replacement: Schritt 3, Bild 1 von 1
    • Using the PH000 screwdriver, remove the 3.8mm screw located inside the HDMI port.
  4. Olympus Digital Camera TG-3 Lens Ring  Replacement: Schritt 4, Bild 1 von 1
    • Locate the bottom section of the camera. Using the PH000 screwdriver, remove the two 4mm screws located towards the middle (near the battery compartment).
  5. Olympus Digital Camera TG-3 Lens Ring  Replacement: Schritt 5, Bild 1 von 1
    • Now you should be able to remove the front case easily using your hand.
  6. Olympus Digital Camera TG-3 Lens Ring  Replacement, Lens Ring: Schritt 6, Bild 1 von 1
    • Twist the ring around the camera lens and pull it out.
Abschluss
USF Tampa, Team 1-6, Leahy Fall 2016 Mitglied von USF Tampa, Team 1-6, Leahy Fall 2016
USFT-LEAHY-F16S1G6
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 5
Letzten 30 Tage: 32
Insgesamt: 1,930
