Zum Hauptinhalt wechseln
Olympus Digital Camera TG-3 Shutter Button Replacement
Was du brauchst
  1. Olympus Digital Camera TG-3 Shutter Button  Replacement, Front Case: Schritt 1, Bild 1 von 1
    • Locate the strap eyelet side of the camera and use the PH000 screwdriver to remove the two 5.3mm screws that hold the strap.
  2. Olympus Digital Camera TG-3 Shutter Button  Replacement: Schritt 2, Bild 1 von 1
    • Locate the side of the camera containing the HDMI port. Use the PH000 screwdriver to remove the 5.4mm screw located on the lower left side below the port.
  3. Olympus Digital Camera TG-3 Shutter Button  Replacement: Schritt 3, Bild 1 von 1
    • Using the PH000 screwdriver, remove the 3.8mm screw located inside the HDMI port.
  4. Olympus Digital Camera TG-3 Shutter Button  Replacement: Schritt 4, Bild 1 von 1
    • Locate the bottom section of the camera. Using the PH000 screwdriver, remove the two 4mm screws located towards the middle (near the battery compartment).
  5. Olympus Digital Camera TG-3 Shutter Button  Replacement: Schritt 5, Bild 1 von 1
    • Now you should be able to remove the front case easily using your hand.
  6. Olympus Digital Camera TG-3 Shutter Button  Replacement, Back Case: Schritt 6, Bild 1 von 1
    • Using the PH000 screwdriver, remove the two 4mm screws located on the left side of the camera, under the strap holder.
  7. Olympus Digital Camera TG-3 Shutter Button  Replacement: Schritt 7, Bild 1 von 1
    • Use a PH000 screwdriver to remove the 3 mm screw located on the bottom of the battery compartment.
  8. Olympus Digital Camera TG-3 Shutter Button  Replacement: Schritt 8, Bild 1 von 1
    • Hold the device as shown in the picture. Using the PH000 screwdriver, remove the 9mm screw located on the upper left side of the camera.
  9. Olympus Digital Camera TG-3 Shutter Button  Replacement: Schritt 9, Bild 1 von 1
    • Use the PH000 screwdriver to remove the 7mm screw you'll find toward the lower left side of the camera.
  10. Olympus Digital Camera TG-3 Shutter Button  Replacement: Schritt 10, Bild 1 von 1
    • Use a PH000 screwdriver to remove the 6mm screw on the upper right side of the camera, above the flash.
  11. Olympus Digital Camera TG-3 Shutter Button  Replacement: Schritt 11, Bild 1 von 1
    • Using the PH000 screwdriver, remove the 1.2 mm located on the lower right side of the device, towards the corner.
  12. Olympus Digital Camera TG-3 Shutter Button  Replacement: Schritt 12, Bild 1 von 1
    • Use the PH0000 screwdriver to remove the 7 mm located on the upper side of the camera, where the shutter and zoom bottoms are. You will find the screw towards the middle of this section.
  13. Olympus Digital Camera TG-3 Shutter Button  Replacement: Schritt 13, Bild 1 von 1
    • Remove the back case using your hand.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Natalia Morales
675 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 1-6, Leahy Fall 2016 Mitglied von USF Tampa, Team 1-6, Leahy Fall 2016
USFT-LEAHY-F16S1G6
3 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
Bravo super tutorial, but how to ensure the sealing after disassembly and reassembly?
vincent vidal - Antwort
I have a problem recovering the original condition. Is it possible Someone help me to restore it. Olympus TG-3 contact back. Witrocker@hotmail.com
Dawis rocker - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 2
Letzten 7 Tage: 10
Letzten 30 Tage: 30
Insgesamt: 2,379
