Zum Hauptinhalt wechseln
Olympus E-Pl1 Sensor Lens Replacement
Was du brauchst
  1. Olympus E-Pl1 Sensor Lens Replacement, Opening The Case: Schritt 1, Bild 1 von 1
    • Push the gray tab down, using a spudger if necessary, and the battery will come out.
    • Failure to remove the battery prior to disassembly can result in harm.
    Frag FixBot
    Kommentar hinzufügen
  2. Olympus E-Pl1 Sensor Lens Replacement: Schritt 2, Bild 1 von 3 Olympus E-Pl1 Sensor Lens Replacement: Schritt 2, Bild 2 von 3 Olympus E-Pl1 Sensor Lens Replacement: Schritt 2, Bild 3 von 3
    • There are a total of six screws that must be removed using the the #000 Philips screwdriver.
    • As per picture one: there is one 4.9 mm Philips head screw on the left side of the camera.
    • As per picture two: on the bottom of the camera, there are three 3.4 mm Philips head screws; these are located on the darker area of the case.
    • As per picture three: there are two 5.3 mm Philips head screws on the right side, one is beneath the USB cover.
    Frag FixBot
  3. Olympus E-Pl1 Sensor Lens Replacement: Schritt 3, Bild 1 von 1
    • Open the case by peeling off the back panel.
    • Pull the case apart gently so that the ribbon connector will not tear.
    Frag FixBot
  4. Olympus E-Pl1 Sensor Lens Replacement: Schritt 4, Bild 1 von 2 Olympus E-Pl1 Sensor Lens Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the two ribbon cables as shown in picture one.
    • Avoid using metal pry tools, as shown in the photo, on internal electronic components, as it can cause a short and damage the device. Use an ESD-safe tool such as a standard nylon spudger.
    • To disconnect a ribbon cable, use a spudger to lift the black tab then pull the ribbon out. This works the same for all ribbon cables.
    Frag FixBot
  5. Olympus E-Pl1 Sensor Lens Replacement: Schritt 5, Bild 1 von 1
    • The back panel has now been removed.
    Frag FixBot
  6. Olympus E-Pl1 Sensor Lens Replacement, Sensor Assembly: Schritt 6, Bild 1 von 3 Olympus E-Pl1 Sensor Lens Replacement, Sensor Assembly: Schritt 6, Bild 2 von 3 Olympus E-Pl1 Sensor Lens Replacement, Sensor Assembly: Schritt 6, Bild 3 von 3
    • Using a spudger, remove the ribbon cables by pushing the black tab back and gently pulling the cable out.
    • Do this process for the two ribbon cables shown in the third photo.
    Frag FixBot
  7. Olympus E-Pl1 Sensor Lens Replacement: Schritt 7, Bild 1 von 2 Olympus E-Pl1 Sensor Lens Replacement: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Using the #000 Phillips screwdriver, remove the 4.3 mm screw as shown by the screwdriver and the 6.0 mm screw holding down the ribbon.
    • These screws have washers on them, do not to lose them.
    • Using tweezers, gently lift the ribbon off the sticky pad.
    Frag FixBot
  8. Olympus E-Pl1 Sensor Lens Replacement: Schritt 8, Bild 1 von 3 Olympus E-Pl1 Sensor Lens Replacement: Schritt 8, Bild 2 von 3 Olympus E-Pl1 Sensor Lens Replacement: Schritt 8, Bild 3 von 3
    • Unlike previous connectors, this cable has a light grey clip holding it in place on opposite side of the connector in regards where the ribbon is inserted. Flip it up and then using your fingers, gently pull the top ribbon cable out.
    Frag FixBot
  9. Olympus E-Pl1 Sensor Lens Replacement: Schritt 9, Bild 1 von 1
    • Using a #000 Phillips screwdriver, remove the 6.0 mm screw on the bottom left hand corner. You can locate the screw on the picture as the green circle.
    Frag FixBot
  10. Olympus E-Pl1 Sensor Lens Replacement: Schritt 10, Bild 1 von 2 Olympus E-Pl1 Sensor Lens Replacement: Schritt 10, Bild 2 von 2
    • In the upper left hand corner, use the #000 Phillips screwdriver to remove the 6.0 mm screw.
    • Retain the copper washer held in by this screw.
    • Using tweezers gently lift the copper grounding strip.
    • Do not tear the strip as you pull it off, it must stay attached to the main camera body.
    Frag FixBot
  11. Olympus E-Pl1 Sensor Lens Replacement: Schritt 11, Bild 1 von 3 Olympus E-Pl1 Sensor Lens Replacement: Schritt 11, Bild 2 von 3 Olympus E-Pl1 Sensor Lens Replacement: Schritt 11, Bild 3 von 3
    • Remove the bracket in the lower right hand corner. In order to do so, you must remove two different screws.
    • Using the #000 Phillips screwdriver, remove the 2.4 mm screw on the bottom.
    • Using the #000 Phillips screwdriver, remove the 6.0 mm screw on the top and lift off the bracket.
    Frag FixBot
  12. Olympus E-Pl1 Sensor Lens Replacement: Schritt 12, Bild 1 von 3 Olympus E-Pl1 Sensor Lens Replacement: Schritt 12, Bild 2 von 3 Olympus E-Pl1 Sensor Lens Replacement: Schritt 12, Bild 3 von 3
    • Now you can lift out the sensor assembly. The following steps will explain how to lift it out.
    • First, sightly lift the bottom half following the direction of the arrow.
    • Second, lift the top left up side up. It may be a little stuck so you will have to wiggle it out.
    • Finally, pull the entire assembly towards the bottom and away from the case.
    • There is a ribbon connector that is beneath the assembly. Be careful when lifting the assembly out. Do not yank it out very hard or you may damage the ribbon connector.
    Frag FixBot
  13. Olympus E-Pl1 Sensor Lens Replacement: Schritt 13, Bild 1 von 3 Olympus E-Pl1 Sensor Lens Replacement: Schritt 13, Bild 2 von 3 Olympus E-Pl1 Sensor Lens Replacement: Schritt 13, Bild 3 von 3
    • This is the sensor assembly with the photo showing the connected ribbon cable.
    • There are three washers held in by the 6.0 mm screws as shown in picture two. Be sure to replace them when reassembling.
    Frag FixBot
  14. Olympus E-Pl1 Sensor Lens Replacement: Schritt 14, Bild 1 von 1
    • The sensor assembly has been removed.
    Frag FixBot
  15. Olympus E-Pl1 Sensor Lens Replacement, Sensor Lens: Schritt 15, Bild 1 von 1
    • Remove the 3 screws surrounding the sensor lens with a #000 Phillips screwdriver.
    Frag FixBot
  16. Olympus E-Pl1 Sensor Lens Replacement: Schritt 16, Bild 1 von 1
    • Using a soldering iron and soldering wick desolder the two wires connecting the lens.
    • take note of the colors of the wire as the new lens must be attached in the same manner.
    • Solder in the new lens. Be sure to match the wire color to the original wire placement.
    Frag FixBot
  17. Olympus E-Pl1 Sensor Lens Replacement: Schritt 17, Bild 1 von 1
    • Remove the sensor lens by pulling back as shown.
    Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Colorado Springs, Team 9-1, Panko Spring 2015 Mitglied von Colorado Springs, Team 9-1, Panko Spring 2015
UCCS-PANKO-S15S9G1
3 Mitglieder
12 Anleitungen geschrieben
2 Kommentare zur Anleitung
Hello. Is it possible to remove glass from sensor without damaging microwires? I want to debayer sensor.
Gediminas Jesinas - Antwort Teilen
Is that a battery on the right in Step 3? Might it be used to keep the clock running while changing the main battery?
914Mike - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 33
Letzte 30 Tage: 112
Insgesamt: 7,356
