Einleitung
This guide is designed to teach an ifixit user to replace the sensor lens for an Olympus E-PL1 camera.
Was du brauchst
Push the gray tab down, using a spudger if necessary, and the battery will come out.
There are a total of six screws that must be removed using the the #000 Philips screwdriver.
As per picture one: there is one 4.9 mm Philips head screw on the left side of the camera.
As per picture two: on the bottom of the camera, there are three 3.4 mm Philips head screws; these are located on the darker area of the case.
As per picture three: there are two 5.3 mm Philips head screws on the right side, one is beneath the USB cover.
Using a spudger, remove the ribbon cables by pushing the black tab back and gently pulling the cable out.
Do this process for the two ribbon cables shown in the third photo.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using the #000 Phillips screwdriver, remove the 4.3 mm screw as shown by the screwdriver and the 6.0 mm screw holding down the ribbon.
Using tweezers, gently lift the ribbon off the sticky pad.
Unlike previous connectors, this cable has a light grey clip holding it in place on opposite side of the connector in regards where the ribbon is inserted. Flip it up and then using your fingers, gently pull the top ribbon cable out.
Using a #000 Phillips screwdriver, remove the 6.0 mm screw on the bottom left hand corner. You can locate the screw on the picture as the green circle.
In the upper left hand corner, use the #000 Phillips screwdriver to remove the 6.0 mm screw.
Using tweezers gently lift the copper grounding strip.
Remove the bracket in the lower right hand corner. In order to do so, you must remove two different screws.
Using the #000 Phillips screwdriver, remove the 2.4 mm screw on the bottom.
Using the #000 Phillips screwdriver, remove the 6.0 mm screw on the top and lift off the bracket.
Now you can lift out the sensor assembly. The following steps will explain how to lift it out.
First, sightly lift the bottom half following the direction of the arrow.
Second, lift the top left up side up. It may be a little stuck so you will have to wiggle it out.
Finally, pull the entire assembly towards the bottom and away from the case.
This is the sensor assembly with the photo showing the connected ribbon cable.
Remove the 3 screws surrounding the sensor lens with a #000 Phillips screwdriver.
Using a soldering iron and soldering wick desolder the two wires connecting the lens.
Solder in the new lens. Be sure to match the wire color to the original wire placement.
3 weitere Personen haben diese Anleitung absolviert.
2 Kommentare zur Anleitung
Hello. Is it possible to remove glass from sensor without damaging microwires? I want to debayer sensor.
