Zum Hauptinhalt wechseln
Olympus E-Pl1 Speaker Replacement
Was du brauchst
  1. Olympus E-Pl1 Speaker Replacement, Opening The Case: Schritt 1, Bild 1 von 1
    • Push the gray tab down, using a spudger if necessary, and the battery will come out.
    • Failure to remove the battery prior to disassembly can result in harm.
    Frag FixBot
  2. Olympus E-Pl1 Speaker Replacement: Schritt 2, Bild 1 von 3 Olympus E-Pl1 Speaker Replacement: Schritt 2, Bild 2 von 3 Olympus E-Pl1 Speaker Replacement: Schritt 2, Bild 3 von 3
    • There are a total of six screws that must be removed using the the #000 Philips screwdriver.
    • As per picture one: there is one 4.9 mm Philips head screw on the left side of the camera.
    • As per picture two: on the bottom of the camera, there are three 3.4 mm Philips head screws; these are located on the darker area of the case.
    • As per picture three: there are two 5.3 mm Philips head screws on the right side, one is beneath the USB cover.
    Frag FixBot
  3. Olympus E-Pl1 Speaker Replacement: Schritt 3, Bild 1 von 1
    • Open the case by peeling off the back panel.
    • Pull the case apart gently so that the ribbon connector will not tear.
    Frag FixBot
  4. Olympus E-Pl1 Speaker Replacement: Schritt 4, Bild 1 von 2 Olympus E-Pl1 Speaker Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the two ribbon cables as shown in picture one.
    • Avoid using metal pry tools, as shown in the photo, on internal electronic components, as it can cause a short and damage the device. Use an ESD-safe tool such as a standard nylon spudger.
    • To disconnect a ribbon cable, use a spudger to lift the black tab then pull the ribbon out. This works the same for all ribbon cables.
    Frag FixBot
  5. Olympus E-Pl1 Speaker Replacement: Schritt 5, Bild 1 von 1
    • The back panel has now been removed.
    Frag FixBot
  6. Olympus E-Pl1 Speaker Replacement, LCD Screen: Schritt 6, Bild 1 von 3 Olympus E-Pl1 Speaker Replacement, LCD Screen: Schritt 6, Bild 2 von 3 Olympus E-Pl1 Speaker Replacement, LCD Screen: Schritt 6, Bild 3 von 3
    • As per picture one: peel back the black strip.
    • As per picture two: peel back the Copper strip.
    • As per picture three: peel back the blue tape.
    Frag FixBot
  7. Olympus E-Pl1 Speaker Replacement: Schritt 7, Bild 1 von 2 Olympus E-Pl1 Speaker Replacement: Schritt 7, Bild 2 von 2
    • There are four screws that need to be removed using the #000 Philips screwdriver.
    • Remove the three 3.4 mm screws on the silver panel.
    • Now remove the 4.3 mm screw located on the green board.
    Frag FixBot
  8. Olympus E-Pl1 Speaker Replacement: Schritt 8, Bild 1 von 1
    • Lift out and remove the metal plating over the LCD screen.
    Frag FixBot
  9. Olympus E-Pl1 Speaker Replacement: Schritt 9, Bild 1 von 2 Olympus E-Pl1 Speaker Replacement: Schritt 9, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use a spudger to lift the brown lock tab.
    • Using tweezers, lift the ribbon cable from the brown lock tab.
    Frag FixBot
  10. Olympus E-Pl1 Speaker Replacement: Schritt 10, Bild 1 von 1
    • Lift out the LCD Screen.
    Frag FixBot
  11. Olympus E-Pl1 Speaker Replacement, Speaker: Schritt 11, Bild 1 von 2 Olympus E-Pl1 Speaker Replacement, Speaker: Schritt 11, Bild 2 von 2
    • Using a spudger lift up the black retainer tab.
    • Gently pull out the ribbon cable.
    Frag FixBot
  12. Olympus E-Pl1 Speaker Replacement: Schritt 12, Bild 1 von 2 Olympus E-Pl1 Speaker Replacement: Schritt 12, Bild 2 von 2
    • Using your fingers, grab the copper grounding strip and blue and black tape.
    • Pull these three back at the same time.
    Frag FixBot
  13. Olympus E-Pl1 Speaker Replacement: Schritt 13, Bild 1 von 2 Olympus E-Pl1 Speaker Replacement: Schritt 13, Bild 2 von 2
    • Using a #000 Phillips screwdriver remove the four 3.7 mm screws holding the board.
    • Using a #000 Phillips screwdriver remove the 4.3 mm screw as shown in picture two as well as the clear plastic sheet.
    Frag FixBot
  14. Olympus E-Pl1 Speaker Replacement: Schritt 14, Bild 1 von 1
    • Gently lift out the board being careful of the wires in the center
    Frag FixBot
  15. Olympus E-Pl1 Speaker Replacement: Schritt 15, Bild 1 von 1
    • With your fingers twist and move the speaker to the other side of the board.
    Frag FixBot
  16. Olympus E-Pl1 Speaker Replacement: Schritt 16, Bild 1 von 1
    • Using a soldering iron and soldering wick desolder the two wires connecting the speaker
    • The new speaker must be attached with the wire colors in the same orientation.
    • Solder in the new speaker. Be sure to match the wire color to the original wire placement.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Colorado Springs, Team 9-1, Panko Spring 2015 Mitglied von Colorado Springs, Team 9-1, Panko Spring 2015
UCCS-PANKO-S15S9G1
3 Mitglieder
12 Anleitungen geschrieben
1 Kommentar zur Anleitung
Dear Jeffery,
thank you very much for this nice tutorial.
Could you please tell us the part number of the speaker you exchanged?
Can’t see the upper part of the number on the pictures: ???1710
Thank you
Sincerely
Lears
Lars Hooge - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 84
Insgesamt: 1,704
