Zum Hauptinhalt wechseln
Olympus OM-D E-M10 Disassembly
Was du brauchst
  1. Olympus OM-D E-M10 Disassembly, Olympus OM-D E-M10 Disassembly: Schritt 1, Bild 1 von 1
  2. Olympus OM-D E-M10 Disassembly: Schritt 2, Bild 1 von 1
    • Remove the lens, battery, SD Card, and EVF eye cup
  3. Olympus OM-D E-M10 Disassembly: Schritt 3, Bild 1 von 1
    • Unscrew all the screws you can find on the outside of the camera, except those on the lens mount and those on the LCD itself. Watch the video for a rundown of each screw location. https://youtu.be/miKYy9vUyWk
  4. Olympus OM-D E-M10 Disassembly: Schritt 4, Bild 1 von 1
    • Use the utility knife to pull the rubber covers from the front of the camera. Don't pull off the thumb grip.
  5. Olympus OM-D E-M10 Disassembly: Schritt 5, Bild 1 von 1
    • Remove the screws from the front of the camera. (not the ones on the silver lens mount)
  6. Olympus OM-D E-M10 Disassembly: Schritt 6, Bild 1 von 1
    • Pull the camera apart.
  7. Olympus OM-D E-M10 Disassembly: Schritt 7, Bild 1 von 1
    • Lift the tiny black flap that holds the ribbon cable for the LCD to the camera body. This releases the ribbon, you shouldn't need to pull on the ribbon with any force.
  8. Olympus OM-D E-M10 Disassembly: Schritt 8, Bild 1 von 1
    • If you want to remove the top plate, you will need to release this ribbon cable, as well as remove two screws on the sides next to the camera strap connection points.
  9. Olympus OM-D E-M10 Disassembly: Schritt 9, Bild 1 von 1
    • You may also need to remove this ribbon cable to lift the top plate.
    • Even after doing all this, you will still not be able to completely remove the top plate, doing so would require a more complete disassembly.
  10. Olympus OM-D E-M10 Disassembly: Schritt 10, Bild 1 von 1
    • From here you can attempt a repair of your device.
    • Salt water damage can often be repaired by rinsing the inside of your camera with isopropyl alcohol or distilled water.
Abschluss
To reassemble your device, follow these instructions in reverse order. You can also view the reassembly in the video: https://youtu.be/miKYy9vUyWk
7 weitere Nutzer:innen haben diese Anleitung absolviert.
nathanael
370 Reputation
1 Anleitung geschrieben
10 Kommentare
When reassembling the camera, is there a preferred and/or recommended adhesive for the grips removed in Step 4?
Thank you
tjod - Antwort
I found the original adhesive was still sticky enough to reassemble without adding anything.
nathanael -
Thanks. I’ll try that. If not possibly some rebber cement will do the trick.
tjod - Antwort
Do you have any experience in dealing with the pop-up flash? Does it contain a bulb or a filament?
aberget@aol.com - Antwort
Thanks for this post! Very useful.
Will it continue for other mirrorless cameras?
I am particularly interested in the information of the e-m5 mark ii. Is its disassembly done in the similar way?
Andrey P - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 30
Letzte 30 Tage: 130
Insgesamt: 11,516
