Zum Hauptinhalt wechseln
Olympus OM-D E-M10 Mark II Motherboard Replacement
Was du brauchst
  1. Olympus OM-D E-M10 Mark II  Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 2 Olympus OM-D E-M10 Mark II  Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Lay the camera on its back as shown. Using the button located to the right of the lens, hold it down while rotating the lens to release it from the camera.
  2. Olympus OM-D E-M10 Mark II  Motherboard Replacement: Schritt 2, Bild 1 von 2 Olympus OM-D E-M10 Mark II  Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Remove eight screws using a Phillips #00 screwdriver.
    • There are 3 different screws, (2x) 3 mm, (3x) 2.5 mm, (3x) 4 mm.
  3. Olympus OM-D E-M10 Mark II  Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Lift and remove the bottom cover off the camera.
  4. Olympus OM-D E-M10 Mark II  Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Using the Phillips #00 remove two 5.0 mm screws, one from each side of the base of the camera.
  5. Olympus OM-D E-M10 Mark II  Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Turn the camera over until it is laying on its backside. Open the screen until it fully extended and perpendicular as shown below. Remove the three screws located there with the Phillips #00.
    • There are two different types of screws. (2x) 2.7 mm, (1x) 3.5 mm.
  6. Olympus OM-D E-M10 Mark II  Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Turn the camera over on its side as shown. There is a small compartment door that has a screw located underneath it. Remove the 2.5 mm screw with a Phillips #00 screwdriver.
  7. Olympus OM-D E-M10 Mark II  Motherboard Replacement: Schritt 7, Bild 1 von 2 Olympus OM-D E-M10 Mark II  Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Take the front and back of the camera apart.
    • Be careful when taking the front and back of the camera apart because there are connecters to the motherboard from both halves which are very fragile. In order to fully take the two halves apart you will need to unhook the connectors from the motherboard.
  8. Olympus OM-D E-M10 Mark II  Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Position the front half as depicted below. The motherboard is the green computer chip on the right half the picture below. You will need to disconnect everything from the motherboard. Gently pull out all orange connectors.
  9. Olympus OM-D E-M10 Mark II  Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Using a Phillips #00 remove the three 3.0 mm screws while holding the motherboard in place. You should then be able to gently remove the motherboard.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
IUPUI, Team S1-G5, Hovde Fall 2019 Mitglied von IUPUI, Team S1-G5, Hovde Fall 2019
IUPUI-HOVDE-F19S1G5
3 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
Good work! My anode selector does not work, I am stuck in AUTO, mines mark iii but looks very similar. Anyone else has this issue?
Phil Rydin - Antwort
This is what Olympus had to say about me replacing the mother board- what are your thoughts. The issue is indeed in the mainboard. However, we don't sell that part and even if you buy it elsewhere, for it to work properly, it will have to be configured with specific codes that only we have and that, as you must understand, are confidential, so, in this case, we suggest that you proceed with the repair.
Dan Ingersoll - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 81
Insgesamt: 4,367
