Zum Hauptinhalt wechseln
Olympus SP-320 Back casing and LCD screen Replacement
Was du brauchst
  1. Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: Schritt 1, Bild 1 von 3 Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: Schritt 1, Bild 2 von 3 Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: Schritt 1, Bild 3 von 3
    • Remove the 3 mm long screws with a Phillips head screwdriver that has a PH000 size bit.
  2. Olympus SP-320 Back casing and LCD screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the 3 mm long screw using Phillips head screwdriver that has a PH000 size bit.
  3. Olympus SP-320 Back casing and LCD screen Replacement: Schritt 3, Bild 1 von 1
    • Pry the outer case open using a blue, plastic opening tool.
    • Pry case open gently to avoid tearing the ribbon that connects the front part of the case to the back of the case.
  4. Olympus SP-320 Back casing and LCD screen Replacement: Schritt 4, Bild 1 von 3 Olympus SP-320 Back casing and LCD screen Replacement: Schritt 4, Bild 2 von 3 Olympus SP-320 Back casing and LCD screen Replacement: Schritt 4, Bild 3 von 3
    • Detach camera body from back casing and LCD screen.
    • Pull gently on the white connecting cable to detach it from the main body of the camera.
    • Lift the small, plastic clip, detaching the ribbon from the main body of the camera.
  5. Olympus SP-320 Back casing and LCD screen Replacement: Schritt 5, Bild 1 von 3 Olympus SP-320 Back casing and LCD screen Replacement: Schritt 5, Bild 2 von 3 Olympus SP-320 Back casing and LCD screen Replacement: Schritt 5, Bild 3 von 3
    • You have detached the back casing and LCD screen.
Abschluss
Ein Kommentar
Is that thin white connector - a powercable to screen led-light? thnx
Alex CalmCroft Tokarsky - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 523
