Zum Hauptinhalt wechseln
Olympus SP-320 Motherboard Replacement
Was du brauchst
  1. Olympus SP-320 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 Olympus SP-320 Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 Olympus SP-320 Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Remove the 3 mm long screws using a Phillips head screwdriver that has a PH000 size bit.
  2. Olympus SP-320 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the 3 mm long screw using a Phillips head screwdriver that has a PH000 size bit.
  3. Olympus SP-320 Motherboard Replacement: Schritt 3, Bild 1 von 2 Olympus SP-320 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Pry the outer case open using a blue, plastic opening tool.
    • Pry case open gently to avoid tearing the ribbon that connects the front part of the case to the back of the case.
  4. Olympus SP-320 Motherboard Replacement: Schritt 4, Bild 1 von 3 Olympus SP-320 Motherboard Replacement: Schritt 4, Bild 2 von 3 Olympus SP-320 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Detach camera body from back casing and LCD screen.
    • Pull gently on the white connecting cable to detach it from the main body of the camera.
    • Lift the small, white, plastic clip detaching the ribbon from the main body of the camera.
  5. Olympus SP-320 Motherboard Replacement: Schritt 5, Bild 1 von 2 Olympus SP-320 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove 2 mm long screws with the Phillips head screwdriver that has a PH000 size bit.
    • Remove 3 mm long screws with the Phillips head screwdriver that has a PH000 size bit.
  6. Olympus SP-320 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Remove motherboard.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Nice description to follow!
Would you know which component is responsible in SP-320 for keeping the date/time while battery is out ?
Every time I remove the battery for replacement, the date/time settings is gone (instantly). Thanks!
Istvan Ujfalvi - Antwort
It would be nice to know why you needed to access the motherboard.
John - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 516
