Einleitung
You will need a clean, well-lit area, an iFixit repair kit including the specialized screw driver, along with the Phillips #000 bit. We also recommend you have an organization tray in order to keep track of all the screws you will be taking out.
Was du brauchst
Remove nine 4.45mm Phillips #000 screws from the outside of the case.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
