Zum Hauptinhalt wechseln
Olympus SZ-12 LCD Screen Replacement
Was du brauchst
  1. Olympus SZ-12 LCD Screen Replacement, Back Case: Schritt 1, Bild 1 von 2 Olympus SZ-12 LCD Screen Replacement, Back Case: Schritt 1, Bild 2 von 2
    • Remove nine 4.45mm Phillips #000 screws from the outside of the case.
  2. Olympus SZ-12 LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • There are four screws to take out on the bottom of the camera.
  3. Olympus SZ-12 LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • There are three screws to take out on this side.
  4. Olympus SZ-12 LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • There is one screw to take out on this side.
  5. Olympus SZ-12 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • There is one hidden screw inside the HDMI port.
  6. Olympus SZ-12 LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Using the blue plastic opening tool, wedge open and remove the case.
  7. Olympus SZ-12 LCD Screen Replacement, LCD Screen: Schritt 7, Bild 1 von 1
    • Once you have the back case off, remove the LCD Screen.
  8. Olympus SZ-12 LCD Screen Replacement: Schritt 8, Bild 1 von 1
    • Using a plastic opening tool, gently lift the retaining flap on the display cable ZIF connector.
    • Pull the display cable from its socket on the motherboard.
  9. Olympus SZ-12 LCD Screen Replacement: Schritt 9, Bild 1 von 1
    • Remove the LCD screen from the device.
    • Be careful not to rip the display's ribbon cable as you pull the screen away from the device.
Abschluss
Samuel Hays
515 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 18
Insgesamt: 550
