Zum Hauptinhalt wechseln
Olympus SZ-12 Lens Replacement
Was du brauchst
  1. Olympus SZ-12 Lens Replacement, Back Case: Schritt 1, Bild 1 von 2 Olympus SZ-12 Lens Replacement, Back Case: Schritt 1, Bild 2 von 2
    • Remove nine 4.45mm Phillips #000 screws from the outside of the case.
  2. Olympus SZ-12 Lens Replacement: Schritt 2, Bild 1 von 1
    • There are four screws to take out on the bottom of the camera.
  3. Olympus SZ-12 Lens Replacement: Schritt 3, Bild 1 von 1
    • There are three screws to take out on this side.
  4. Olympus SZ-12 Lens Replacement: Schritt 4, Bild 1 von 1
    • There is one screw to take out on this side.
  5. Olympus SZ-12 Lens Replacement: Schritt 5, Bild 1 von 1
    • There is one hidden screw inside the HDMI port.
  6. Olympus SZ-12 Lens Replacement: Schritt 6, Bild 1 von 1
    • Using the blue plastic opening tool, wedge open and remove the case.
  7. Olympus SZ-12 Lens Replacement, LCD Screen: Schritt 7, Bild 1 von 1
    • Once you have the back case off, remove the LCD Screen.
  8. Olympus SZ-12 Lens Replacement: Schritt 8, Bild 1 von 1
    • Using a plastic opening tool, gently lift the retaining flap on the display cable ZIF connector.
    • Pull the display cable from its socket on the motherboard.
  9. Olympus SZ-12 Lens Replacement: Schritt 9, Bild 1 von 1
    • Remove the LCD screen from the device.
    • Be careful not to rip the display's ribbon cable as you pull the screen away from the device.
  10. Olympus SZ-12 Lens Replacement, Lens: Schritt 10, Bild 1 von 2 Olympus SZ-12 Lens Replacement, Lens: Schritt 10, Bild 2 von 2
    • Remove the four 3.8mm Phillips #000 screws from the LCD frame.
  11. Olympus SZ-12 Lens Replacement: Schritt 11, Bild 1 von 3 Olympus SZ-12 Lens Replacement: Schritt 11, Bild 2 von 3 Olympus SZ-12 Lens Replacement: Schritt 11, Bild 3 von 3
    • Remove the top left screw, top right screw, bottom left screw, and bottom right screw from LCD frame.
  12. Olympus SZ-12 Lens Replacement: Schritt 12, Bild 1 von 3 Olympus SZ-12 Lens Replacement: Schritt 12, Bild 2 von 3 Olympus SZ-12 Lens Replacement: Schritt 12, Bild 3 von 3
    • Lift the retaining flaps on the three remaining ZIF connectors connected to the motherboard.
  13. Olympus SZ-12 Lens Replacement: Schritt 13, Bild 1 von 1
    • Remove the five 4.3mm Phillips #000 screws from the lens frame to access the lens.
    • Remove the lens frame.
  14. Olympus SZ-12 Lens Replacement: Schritt 14, Bild 1 von 3 Olympus SZ-12 Lens Replacement: Schritt 14, Bild 2 von 3 Olympus SZ-12 Lens Replacement: Schritt 14, Bild 3 von 3
    • Remove two 4.3mm Phillips #000 screws from black plastic piece surrounding the lens.
    • Remove the lens.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Samuel Hays
515 Reputation
4 Anleitungen geschrieben
Ein Kommentar
Is her anything in the lens assembly that I could look for which may have dislodged showing up as a shadow on the bottom of the display screen
Deacon - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 17
Letzte 30 Tage: 26
Insgesamt: 1,635
