Zum Hauptinhalt wechseln
Olympus Stylus 1030 SW AV Port Replacement
Was du brauchst
  1. Olympus Stylus 1030 SW AV Port Replacement, AV Port: Schritt 1, Bild 1 von 3 Olympus Stylus 1030 SW AV Port Replacement, AV Port: Schritt 1, Bild 2 von 3 Olympus Stylus 1030 SW AV Port Replacement, AV Port: Schritt 1, Bild 3 von 3
    • Use your screwdriver with a Phillips #00 screwdriver to remove all three screws.
    • Use your hand to lift and remove the front case.
  2. Olympus Stylus 1030 SW AV Port Replacement: Schritt 2, Bild 1 von 3 Olympus Stylus 1030 SW AV Port Replacement: Schritt 2, Bild 2 von 3 Olympus Stylus 1030 SW AV Port Replacement: Schritt 2, Bild 3 von 3
    • Remove the rear case.
    • Use a Phillips #00 screwdriver to remove both screws from the side panel.
    • Remove both screws from the battery door.
  3. Olympus Stylus 1030 SW AV Port Replacement: Schritt 3, Bild 1 von 1
    • Flip the Olympus Stylus 1030 SW camera upside down, the rear side facing away from you.
  4. Olympus Stylus 1030 SW AV Port Replacement: Schritt 4, Bild 1 von 2 Olympus Stylus 1030 SW AV Port Replacement: Schritt 4, Bild 2 von 2
    • Flip your camera with the rear side facing away from you. Take your screw driver with the #00 size to remove both screws.
    • Remove the front case.
  5. Olympus Stylus 1030 SW AV Port Replacement: Schritt 5, Bild 1 von 3 Olympus Stylus 1030 SW AV Port Replacement: Schritt 5, Bild 2 von 3 Olympus Stylus 1030 SW AV Port Replacement: Schritt 5, Bild 3 von 3
    • Start with the rear end facing away from you.
    • Use a Phillips #00 size to remove both screws.
    • Flip the camera to the front facing you.
    • Remove the single Phillips #00 screw.
  6. Olympus Stylus 1030 SW AV Port Replacement: Schritt 6, Bild 1 von 3 Olympus Stylus 1030 SW AV Port Replacement: Schritt 6, Bild 2 von 3 Olympus Stylus 1030 SW AV Port Replacement: Schritt 6, Bild 3 von 3
    • To get to the AV port use a spudger to separate the camera.
  7. Olympus Stylus 1030 SW AV Port Replacement: Schritt 7, Bild 1 von 2 Olympus Stylus 1030 SW AV Port Replacement: Schritt 7, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the remaining two screws from the motherboard.
  8. Olympus Stylus 1030 SW AV Port Replacement: Schritt 8, Bild 1 von 2 Olympus Stylus 1030 SW AV Port Replacement: Schritt 8, Bild 2 von 2
    • Use your fingers to lift the black flap and use a Phillips #00 screwdriver to remove the two screws.
  9. Olympus Stylus 1030 SW AV Port Replacement: Schritt 9, Bild 1 von 2 Olympus Stylus 1030 SW AV Port Replacement: Schritt 9, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • With your tweezers from your kit, take out the motherboard of the camera.
    • Once the motherboard is removed separate the motherboard.
    • The AV port is visible, use your spatula to wedge between the AV port to remove.
Abschluss
Alexis Sulzle
301 Reputation
2 Anleitungen geschrieben
Casper College, Team 1-4, Lareau Spring 2023 Mitglied von Casper College, Team 1-4, Lareau Spring 2023
CASC-LAREAU-S23S1G4
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 92
