Zum Hauptinhalt wechseln
Olympus Stylus 1030 SW Flash Assembly Replacement
Was du brauchst
  1. Olympus Stylus 1030 SW Flash Assembly Replacement, Flash Assembly: Schritt 1, Bild 1 von 3 Olympus Stylus 1030 SW Flash Assembly Replacement, Flash Assembly: Schritt 1, Bild 2 von 3 Olympus Stylus 1030 SW Flash Assembly Replacement, Flash Assembly: Schritt 1, Bild 3 von 3
    • Remove the three screws in the corner of the front plate using a Phillips #00 screwdriver.
    • Lift up on the plate until it comes off the rest of the camera.
  2. Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 2, Bild 1 von 3 Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 2, Bild 2 von 3 Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 2, Bild 3 von 3
    • Use the Phillips #00 screwdriver to remove the two screws on both of the side plates of the camera.
  3. Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 3, Bild 1 von 1
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera.
  4. Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 4, Bild 1 von 2 Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 4, Bild 2 von 2
    • Turn the camera so the short side without the av port is facing you.
    • Remove both of the screws on this side using the Phillips #00 screwdriver.
    • Remove the front case.
  5. Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 5, Bild 1 von 3 Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 5, Bild 2 von 3 Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 5, Bild 3 von 3
    • Face the camera so the short side with the AV port facing you. Use your Phillips #00 screwdriver to remove the single screw.
    • Turn your camera so the other short side is facing you. Use the Phillips #00 screwdriver to remove the two screws on the silver parts.
    • Face the bottom of your camera towards you and remove the single screw using the Phillips #00 screwdriver.
  6. Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 6, Bild 1 von 3 Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 6, Bild 2 von 3 Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 6, Bild 3 von 3
    • Open the battery door and use your Phillips #00 screwdriver to remove the screw in the middle of the opening.
    • Use the spudger to pry at the rear case until it comes off.
  7. Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 7, Bild 1 von 2 Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 7, Bild 2 von 2
    • Flip the camera so the front is facing you.
    • Use your Phillips #00 screwdriver to remove the three screws located in the corners on this side.
  8. Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 8, Bild 1 von 1
    • Turn the camera so you are looking at the top.
    • Use your Phillips #00 screwdriver to remove the single screw.
  9. Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 9, Bild 1 von 3 Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 9, Bild 2 von 3 Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 9, Bild 3 von 3
    • Use your spudger to gently pry at the side of the LCD screen and the cover over it.
    • Gently take it apart, using caution with the motherboard and battery.
  10. Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 10, Bild 1 von 3 Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 10, Bild 2 von 3 Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 10, Bild 3 von 3
    • Use your Phillips #00 screwdriver to remove the three screws.
  11. Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 11, Bild 1 von 3 Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 11, Bild 2 von 3 Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 11, Bild 3 von 3
  12. Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 12, Bild 1 von 1
    • Pull the foam to the side gently and use your Phillips #00 screwdriver to remove the single screw.
  13. Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 13, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Use your tweezers to gently pull the motherboard out of the camera.
  14. Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 14, Bild 1 von 2 Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 14, Bild 2 von 2
    • Use your Phillips #00 screwdriver to remove the two screws holding the wires to the flash assembly.
  15. Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 15, Bild 1 von 2 Olympus Stylus 1030 SW Flash Assembly Replacement: Schritt 15, Bild 2 von 2
    • Use your tweezers to gently remove the last wires connected to the flash assembly.
Abschluss
Paige Asmus
241 Reputation
1 Anleitung geschrieben
Casper College, Team 1-4, Lareau Spring 2023 Mitglied von Casper College, Team 1-4, Lareau Spring 2023
CASC-LAREAU-S23S1G4
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 92
