Zum Hauptinhalt wechseln
Olympus Stylus 1030 SW Motherboard Replacement
Was du brauchst
  1. Olympus Stylus 1030 SW Motherboard Replacement, Olympus Stylus 1030 SW Camera Disassembly: Schritt 1, Bild 1 von 3 Olympus Stylus 1030 SW Motherboard Replacement, Olympus Stylus 1030 SW Camera Disassembly: Schritt 1, Bild 2 von 3 Olympus Stylus 1030 SW Motherboard Replacement, Olympus Stylus 1030 SW Camera Disassembly: Schritt 1, Bild 3 von 3
    • Using the iFixit Opening Tool, pry off the plastic part of the lens.
    • Using the T6 Torx screwdriver, unscrew the three screws.
  2. Olympus Stylus 1030 SW Motherboard Replacement: Schritt 2, Bild 1 von 3 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 2, Bild 2 von 3 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Using the Phillips #00 screwdriver, unscrew the three screws.
    • Carefully swivel the metal cover out towards you.
    • Using tweezers, remove the metal washer.
  3. Olympus Stylus 1030 SW Motherboard Replacement: Schritt 3, Bild 1 von 2 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Using the tweezers, slowly peel off the plate.
  4. Olympus Stylus 1030 SW Motherboard Replacement: Schritt 4, Bild 1 von 3 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 4, Bild 2 von 3 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Using the Phillips #00 screwdriver, unscrew the two screws on the side of the camera.
  5. Olympus Stylus 1030 SW Motherboard Replacement: Schritt 5, Bild 1 von 3 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 5, Bild 2 von 3 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 5, Bild 3 von 3
    • On the opposite side, use the Phillips #00 screwdriver to unscrew both screws.
    • Take out the speaker plate.
    • Open the multi-connector cover and slide off the side panel.
  6. Olympus Stylus 1030 SW Motherboard Replacement: Schritt 6, Bild 1 von 3 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 6, Bild 2 von 3 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Using the Phillips #00 screwdriver, unscrew the screw above the speaker.
    • On the bottom side of the camera, unscrew the two screws.
  7. Olympus Stylus 1030 SW Motherboard Replacement: Schritt 7, Bild 1 von 3 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 7, Bild 2 von 3 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Open the battery compartment cover.
    • Use the Phillips #00 screwdriver to unscrew the screw in the battery compartment.
  8. Olympus Stylus 1030 SW Motherboard Replacement: Schritt 8, Bild 1 von 3 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 8, Bild 2 von 3 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 8, Bild 3 von 3
    • On the front of the camera, unscrew the two screws shown.
    • Gently pull on the side until the camera is separated from the back panel.
    • Remove the shutter and power button.
  9. Olympus Stylus 1030 SW Motherboard Replacement: Schritt 9, Bild 1 von 3 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 9, Bild 2 von 3 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Use the Phillips #00 screwdriver to unscrew the four screws on the front of the camera.
    • Unscrew the shutter using the Phillips #00 screwdriver.
  10. Olympus Stylus 1030 SW Motherboard Replacement: Schritt 10, Bild 1 von 2 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Release the top holding using a spudger.
    • Slowly and carefully separate the front and back of the camera, exposing the electrical ribbons.
  11. Olympus Stylus 1030 SW Motherboard Replacement: Schritt 11, Bild 1 von 3 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 11, Bild 2 von 3 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 11, Bild 3 von 3
    • Using the spudger and tweezers if needed, remove the ribbons from the computer chips.
  12. Olympus Stylus 1030 SW Motherboard Replacement, Motherboard: Schritt 12, Bild 1 von 3 Olympus Stylus 1030 SW Motherboard Replacement, Motherboard: Schritt 12, Bild 2 von 3 Olympus Stylus 1030 SW Motherboard Replacement, Motherboard: Schritt 12, Bild 3 von 3
    • Remove the 1.0 cm and the 0.8 mm screws.
    • Peel off tape and remove ribbons.
    • Remove black plastic cover and unscrew the 1.1 cm screw.
  13. Olympus Stylus 1030 SW Motherboard Replacement: Schritt 13, Bild 1 von 2 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 13, Bild 2 von 2
    • Release ribbons carefully using either tweezers or a spudger.
    • Remove the 1.1 cm screw.
  14. Olympus Stylus 1030 SW Motherboard Replacement: Schritt 14, Bild 1 von 3 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 14, Bild 2 von 3 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 14, Bild 3 von 3
    • Push A/V port away from you carefully using a spudger.
    • Slowly take out the motherboard and the speaker microphone.
    • Collect the metal washer plate from the top right corner of the motherboard (now loose).
  15. Olympus Stylus 1030 SW Motherboard Replacement: Schritt 15, Bild 1 von 2 Olympus Stylus 1030 SW Motherboard Replacement: Schritt 15, Bild 2 von 2
    • With a spudger or finger, slowly take out the battery hinged to the motherboard.
    • Be careful not to disconnect the wires by pulling it too hard.
    • Take out motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
3 Kommentare
what is the voltage, and capacitance of the main flash capacitor? diameter and length? I want to replace mine as my 'flash charging' symbol constantly flashes and flash does not fire.
thanks for the writeup! I have more confidence in repairing my 10+ year old camera
Kevin Kay - Antwort
the cap is 330uF and 90V
dimensions:
11.94mm diameter
25.65mm length
Kevin Kay - Antwort
How would I go about extracting the camera module and hooking it up to an arduino?
My cam got saltwater damage however it still turns on for a few seconds before turning off again
GoodNight Tea - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 15
Insgesamt: 1,105
