Einleitung
If your Olympus Stylus (1030 SW) camera has multiple damage parts, such as both front and rear cases, flash assembly, the AV port, or the batter door, you can use this guide to replace these parts.
Using this guide you will find how to replace damage products of the Olympus Stylus (130 SW). Before using our guide you should make sure the camera is powered off, and inspect for any damaged or missing pieces.
Was du brauchst
Start by removing the front case of the Olympus Stylus 1030 SW.
Use a Phillips #00 screwdriver to unscrew the three screws.
Once all three screws are removed, take your hand to remove the front case from the camera. You will lift until it is fully off.
Use a Phillips #00 screwdriver to remove the screws from the side panel.
Use a Phillips #00 screwdriver to remove both of the screws from the battery door.
Flip the Olympus Stylus 1030 SW camera upside down, the rear side facing away from you.
Use a Phillips #00 screwdriver to remove both screws.
Now flip your camera with the rear side facing away from you. Remove both Phillips #00 screws.
You should now be able to remove the front case.
To remove the rear case of the camera, start with the rear end facing away from you.
Remove the two Phillips #00 screws.
Then flip the camera to the front facing you.
Remove the single Phillips #0 screw.
Now place your camera right side up with the front facing you.
Open the battery door and locate the screw placed in the middle.
Remove the Phillips #00 screw.
You now take your spatula to separate the rear case from the camera.
