Einleitung
Use this guide to replace a broken lens inside the camera.
Ersatzteile
Kein Ersatzteil erforderlich.
Unscrew the 3mm long cover screws at the corners of the camera using a #00 Philips Screwdriver.
Unscrew the 2mm long screws securing the sides of the camera which holds the back panel. Use the same screwdriver.
Remove the top screws using a 1.5 mm screwdriver.
Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
Using a #00 Philips Head Screwdriver, remove the screws located on all four sides of the camera.
Remove four metal tabs from corners where the 2mm long screws were attached using tweezers.
Remove the viewfinder lens using a prying device.
There will be two ribbons attached to the viewfinder. Remove the ribbons by sliding them off the viewfinder with your thumb.
