Zum Hauptinhalt wechseln
Olympus Stylus 760 LCD Screen Replacement
Was du brauchst
  1. Olympus Stylus 760 LCD Screen Replacement, Battery door: Schritt 1, Bild 1 von 1
    • Slide the door located on the bottom of the camera in an outward direction
  2. Olympus Stylus 760 LCD Screen Replacement, Release: Schritt 2, Bild 1 von 1
    • Pull back on the red release tab located on the left side of the battery.
  3. Olympus Stylus 760 LCD Screen Replacement, Replacement: Schritt 3, Bild 1 von 1
    • Slide battery out of camera
  4. Olympus Stylus 760 LCD Screen Replacement, LCD Screen: Schritt 4, Bild 1 von 1
    • Remove the 2 screws from the bottom of the camera
  5. Olympus Stylus 760 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Using a Phillips head size 0 screwdriver, remove the screw from the right side of the camera
  6. Olympus Stylus 760 LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Remove the 2 screws from the left side of the camera
  7. Olympus Stylus 760 LCD Screen Replacement: Schritt 7, Bild 1 von 3 Olympus Stylus 760 LCD Screen Replacement: Schritt 7, Bild 2 von 3 Olympus Stylus 760 LCD Screen Replacement: Schritt 7, Bild 3 von 3
    • Separate the front casing from the back using a plastic opening tool, gently.
    • Silver band and buttons will become loose when you remove the two pieces.
  8. Olympus Stylus 760 LCD Screen Replacement: Schritt 8, Bild 1 von 2 Olympus Stylus 760 LCD Screen Replacement: Schritt 8, Bild 2 von 2
    • Pull the silver bracket off of the camera
  9. Olympus Stylus 760 LCD Screen Replacement: Schritt 9, Bild 1 von 3 Olympus Stylus 760 LCD Screen Replacement: Schritt 9, Bild 2 von 3 Olympus Stylus 760 LCD Screen Replacement: Schritt 9, Bild 3 von 3
    • Remove the 4 screws on the inner face of the camera.
    • Circuit ribbon is attached at the top left of the camera. Be careful when separating the front and back of the camera.
    • Pull the camera apart into 2 separate pieces.
  10. Olympus Stylus 760 LCD Screen Replacement: Schritt 10, Bild 1 von 1
    • You should be left with 4 large pieces, the outer case, inner lens piece, outer silver band and back case containing the LCD display.
  11. Olympus Stylus 760 LCD Screen Replacement: Schritt 11, Bild 1 von 2 Olympus Stylus 760 LCD Screen Replacement: Schritt 11, Bild 2 von 2
    • Remove 4 screws holding the LCD screen in place.
    • Be cautious of the brackets that come loose when you remove the 3 screws on the right side of the camera
    • LCD Screen is attached to 2 ribbon wires
  12. Olympus Stylus 760 LCD Screen Replacement: Schritt 12, Bild 1 von 2 Olympus Stylus 760 LCD Screen Replacement: Schritt 12, Bild 2 von 2
    • Pull up on the small ribbon wire to disconnect it from the circuit board
    • Flip the little black clip up to remove the larger ribbon wire from the circuit board.
  13. Olympus Stylus 760 LCD Screen Replacement: Schritt 13, Bild 1 von 1
    • Using a plastic separating tool, remove the LCD screen from the plastic casing.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
James Madison, Team 3-3, Klein Spring 2012 Mitglied von James Madison, Team 3-3, Klein Spring 2012
JMU-KLEIN-S12S3G3
4 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
from where i can get repaired u760 camera
tahir zafar - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 1,508
