Zum Hauptinhalt wechseln
Olympus Stylus Tough 6020 Lens Replacement
Was du brauchst
  1. Olympus Stylus Tough 6020 Lens Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide and push the battery casing to open it.
    • Push the battery to eject it.
  2. Olympus Stylus Tough 6020 Lens Replacement, Bottom Plating: Schritt 2, Bild 1 von 3 Olympus Stylus Tough 6020 Lens Replacement, Bottom Plating: Schritt 2, Bild 2 von 3 Olympus Stylus Tough 6020 Lens Replacement, Bottom Plating: Schritt 2, Bild 3 von 3
    • Turn the camera so that you are facing the bottom of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws on the bottom of the camera.
    • Using a spudger, pry off the plating on the bottom of the camera.
  3. Olympus Stylus Tough 6020 Lens Replacement, Top Plating: Schritt 3, Bild 1 von 3 Olympus Stylus Tough 6020 Lens Replacement, Top Plating: Schritt 3, Bild 2 von 3 Olympus Stylus Tough 6020 Lens Replacement, Top Plating: Schritt 3, Bild 3 von 3
    • Turn the camera so that you are facing the top of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws located on the top of the camera.
    • Using a spudger, pry off the plating on the top of the camera.
  4. Olympus Stylus Tough 6020 Lens Replacement, Left Plating: Schritt 4, Bild 1 von 2 Olympus Stylus Tough 6020 Lens Replacement, Left Plating: Schritt 4, Bild 2 von 2
    • Turn the camera so the LCD is facing upwards.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws located on the left side of the device.
  5. Olympus Stylus Tough 6020 Lens Replacement, Black "Olympus" Face Plate: Schritt 5, Bild 1 von 3 Olympus Stylus Tough 6020 Lens Replacement, Black "Olympus" Face Plate: Schritt 5, Bild 2 von 3 Olympus Stylus Tough 6020 Lens Replacement, Black "Olympus" Face Plate: Schritt 5, Bild 3 von 3
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located next to the black "Olympus" face plate.
    • Using a T6 Torx screwdriver, unscrew the two 3.5mm screws located on the black "Olympus" face plate.
    • Using a spudger, gently pry off the black "Olympus" face plate.
  6. Olympus Stylus Tough 6020 Lens Replacement, End Casing: Schritt 6, Bild 1 von 3 Olympus Stylus Tough 6020 Lens Replacement, End Casing: Schritt 6, Bild 2 von 3 Olympus Stylus Tough 6020 Lens Replacement, End Casing: Schritt 6, Bild 3 von 3
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws to the right of the cursor pad on the U-shaped frame.
    • Turn the device over so the front of the camera is facing you.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws on the end casing.
    • Using a spudger, pry off the end casing.
  7. Olympus Stylus Tough 6020 Lens Replacement, Blue Face Plate: Schritt 7, Bild 1 von 3 Olympus Stylus Tough 6020 Lens Replacement, Blue Face Plate: Schritt 7, Bild 2 von 3 Olympus Stylus Tough 6020 Lens Replacement, Blue Face Plate: Schritt 7, Bild 3 von 3
    • Turn the camera so the blue face plate is visible.
    • Using a Phillips 00 screwdriver, unscrew the two 3mm screws on the blue plate.
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located at the bottom of the camera straight down from the flash.
    • Using a spudger, gently pry off the blue face plate.
  8. Olympus Stylus Tough 6020 Lens Replacement, Back Plate: Schritt 8, Bild 1 von 1
    • Using a Phillips 00 screwdriver, unscrew the 9mm screws on the top of the camera to the right of the flash.
  9. Olympus Stylus Tough 6020 Lens Replacement: Schritt 9, Bild 1 von 3 Olympus Stylus Tough 6020 Lens Replacement: Schritt 9, Bild 2 von 3 Olympus Stylus Tough 6020 Lens Replacement: Schritt 9, Bild 3 von 3
    • Using a Phillips 00 screwdriver, unscrew the wide 3.5mm screw located in the middle of the camera.
    • Using a Phillips 00 screwdriver, unscrew the 9mm screw located at the top left corner of the camera.
    • Using a spudger, separate the black plate from the camera.
  10. Olympus Stylus Tough 6020 Lens Replacement, Lens: Schritt 10, Bild 1 von 1
    • Unscrew screws on place holder plates
  11. Olympus Stylus Tough 6020 Lens Replacement: Schritt 11, Bild 1 von 1
    • Gently lift Lens compartment out of device.
  12. Olympus Stylus Tough 6020 Lens Replacement: Schritt 12, Bild 1 von 1
    • From top view, unscrew 3 screws
    • Do not worry about the screw on top of the 2 screws.
  13. Olympus Stylus Tough 6020 Lens Replacement: Schritt 13, Bild 1 von 2 Olympus Stylus Tough 6020 Lens Replacement: Schritt 13, Bild 2 von 2
    • Lens comes off
Abschluss
Violeta
101 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 538
