Einleitung
I will be providing clear and easy steps on how to replace your Lens Cover on your Olympus Stylus Tough-6000 Digital Camera.
Was du brauchst
You will want to disassemble the camera to get to the Lens Cover.
There are two screws on the right side of the camera.
Use your Phillips #00 screwdriver and unscrew both screws.
You will be able to pull the speaker hat off.
You must pull the speaker hat off to be able to pry the front shell of the camera apart.
Once you have the camera shell cover off you can see the lens cover.
Unscrew the lens cover with your Phillips #00 screwdriver to replace it with a new lens cover.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
