Einleitung
This guide will show clear and easy steps on how to replace the On/Off button.
Was du brauchst
First sit the camera on its bottom. You will be working on the on/off button.
Place camera upward.
Use your Phillips #00 screwdriver to unscrew the two screws.
Unscrew the single screw with your Phillips #00 screwdriver.
This will allow you to pry the panel off.
Once the panel is lifted you will want to lift up the cover for the on/off button.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
