Zum Hauptinhalt wechseln
Olympus Stylus Tough-6000 On/Off Button Replacement
Was du brauchst
  1. Olympus Stylus Tough-6000 On/Off Button Replacement, Locate On/Off Button.: Schritt 1, Bild 1 von 1
    • First sit the camera on its bottom. You will be working on the on/off button.
  2. Olympus Stylus Tough-6000 On/Off Button Replacement: Schritt 2, Bild 1 von 1
    • Place camera upward.
    • You will notice two screws near the on/off button.
    • Use your Phillips #00 screwdriver to unscrew the two screws.
  3. Olympus Stylus Tough-6000 On/Off Button Replacement: Schritt 3, Bild 1 von 1
    • After unscrewing the two screws near the on/off button you will notice a single screw to your right.
    • Unscrew the single screw with your Phillips #00 screwdriver.
    • This will allow you to pry the panel off.
  4. Olympus Stylus Tough-6000 On/Off Button Replacement: Schritt 4, Bild 1 von 1
    • Grab your plastic opening tool and start prying off the panel.
  5. Olympus Stylus Tough-6000 On/Off Button Replacement: Schritt 5, Bild 1 von 1
    • Once the panel is lifted you will want to lift up the cover for the on/off button.
    • The actual on/off button is very small and loose so make sure to be careful with it!
  6. Olympus Stylus Tough-6000 On/Off Button Replacement: Schritt 6, Bild 1 von 1
    • You have reached the on/off button.
    • You can now replace it!
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015 Mitglied von USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015
USFSM-STEWART-W15S1G1
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 566
