Zum Hauptinhalt wechseln
Olympus Stylus Tough-8010 Side Panel Replacement
Was du brauchst
  1. Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: Schritt 1, Bild 1 von 3 Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: Schritt 1, Bild 2 von 3 Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: Schritt 1, Bild 3 von 3
    • Remove the three screws (3.2mm) from the front panel using a T-6 screwdriver.
    • Take off the smaller front panel cover.
    • Carefully remove the larger front cover.
  2. Olympus Stylus Tough-8010 Side Panel Replacement: Schritt 2, Bild 1 von 3 Olympus Stylus Tough-8010 Side Panel Replacement: Schritt 2, Bild 2 von 3 Olympus Stylus Tough-8010 Side Panel Replacement: Schritt 2, Bild 3 von 3
    • Remove the top two screws (4.1mm) using a #000 Phillips head screwdriver.
    • Remove the two screws (7.9mm) near the control pad. Set metal connector aside.
    • Remove the side panel casing.
  3. Olympus Stylus Tough-8010 Side Panel Replacement: Schritt 3, Bild 1 von 3 Olympus Stylus Tough-8010 Side Panel Replacement: Schritt 3, Bild 2 von 3 Olympus Stylus Tough-8010 Side Panel Replacement: Schritt 3, Bild 3 von 3
    • Using a #000 Philips head screwdriver, remove the two screws (4.1mm) on the right side of the camera.
    • Remove the two screws (4.1mm) from the bottom of the camera.
    • Remove the single screw (3.2mm) from the front of the camera.
  4. Olympus Stylus Tough-8010 Side Panel Replacement: Schritt 4, Bild 1 von 2 Olympus Stylus Tough-8010 Side Panel Replacement: Schritt 4, Bild 2 von 2
    • Carefully remove the front panel piece.
    • Remove the screw (7.9mm) from the bottom left hand corner using a #000 Phillips head screwdriver.
  5. Olympus Stylus Tough-8010 Side Panel Replacement: Schritt 5, Bild 1 von 3 Olympus Stylus Tough-8010 Side Panel Replacement: Schritt 5, Bild 2 von 3 Olympus Stylus Tough-8010 Side Panel Replacement: Schritt 5, Bild 3 von 3
    • Slightly bend the metal that is covering the side panel axle.
    • Using a paperclip, completely push out the metal bar that holds the side panel to the camera.
    • Remove the side panel door.
Abschluss
James G Payne
225 Reputation
2 Anleitungen geschrieben
Baylor, Team 7-15, Williams Spring 2015 Mitglied von Baylor, Team 7-15, Williams Spring 2015
BU-WILLIAMS-S15S7G15
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 346
