Zum Hauptinhalt wechseln
Olympus TG-820 iHS Locking Mechanism Replacement
Was du brauchst
  1. Olympus TG-820 iHS Locking Mechanism Replacement, Battery: Schritt 1, Bild 1 von 1
    • Orient camera to look directly at battery compartment side as shown.
    Frag FixBot
  2. Olympus TG-820 iHS Locking Mechanism Replacement: Schritt 2, Bild 1 von 3 Olympus TG-820 iHS Locking Mechanism Replacement: Schritt 2, Bild 2 von 3 Olympus TG-820 iHS Locking Mechanism Replacement: Schritt 2, Bild 3 von 3
    • Locate the two latches on the battery compartment.
    • First, move the "lock" switch left to reveal red indicator.
    • Next, move the "cover latch" switch downward to reveal red indicator.
    • You have to move the switches in that order for the compartment to unlatch.
    Frag FixBot
  3. Olympus TG-820 iHS Locking Mechanism Replacement: Schritt 3, Bild 1 von 2 Olympus TG-820 iHS Locking Mechanism Replacement: Schritt 3, Bild 2 von 2
    • Allow the battery compartment latch to completely open.
    • Insert battery with the writing face up.
    • The bigger slot is for the battery. The smaller slot is for the memory card.
    • Battery not shown.
    Frag FixBot
  4. Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: Schritt 4, Bild 1 von 3 Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: Schritt 4, Bild 2 von 3 Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: Schritt 4, Bild 3 von 3
    • Locate and remove the 4.7mm Phillips #000 screw on the back side of the battery compartment locking mechanism.
    • Locate and remove the 4.7mm Phillips #000 screw on the front side of the battery compartment locking mechanism.
    Frag FixBot
  5. Olympus TG-820 iHS Locking Mechanism Replacement: Schritt 5, Bild 1 von 1
    • Locate the two screws on the side of the battery compartment.
    • Remove the two 4.85mm Phillips #000 screws.
    Frag FixBot
  6. Olympus TG-820 iHS Locking Mechanism Replacement: Schritt 6, Bild 1 von 2 Olympus TG-820 iHS Locking Mechanism Replacement: Schritt 6, Bild 2 von 2
    • Once all 4 screws are out, the back panel of the battery compartment will come off.
    • The entire battery compartment cover will also detach from the camera.
    Frag FixBot
Abschluss
Clemson, Team 7-2, Benson Spring 2016 Mitglied von Clemson, Team 7-2, Benson Spring 2016
CLEM-BENSON-S16S7G2
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 40
Insgesamt: 759
