Zum Hauptinhalt wechseln
Olympus TG-820 iHS Top Buttons Replacement
Was du brauchst
  1. Olympus TG-820 iHS Top Buttons Replacement, Battery: Schritt 1, Bild 1 von 1
    • Orient camera to look directly at battery compartment side as shown.
    Frag FixBot
    Kommentar hinzufügen
  2. Olympus TG-820 iHS Top Buttons Replacement: Schritt 2, Bild 1 von 3 Olympus TG-820 iHS Top Buttons Replacement: Schritt 2, Bild 2 von 3 Olympus TG-820 iHS Top Buttons Replacement: Schritt 2, Bild 3 von 3
    • Locate the two latches on the battery compartment.
    • First, move the "lock" switch left to reveal red indicator.
    • Next, move the "cover latch" switch downward to reveal red indicator.
    • You have to move the switches in that order for the compartment to unlatch.
    Frag FixBot
  3. Olympus TG-820 iHS Top Buttons Replacement: Schritt 3, Bild 1 von 2 Olympus TG-820 iHS Top Buttons Replacement: Schritt 3, Bild 2 von 2
    • Allow the battery compartment latch to completely open.
    • Insert battery with the writing face up.
    • The bigger slot is for the battery. The smaller slot is for the memory card.
    • Battery not shown.
    Frag FixBot
  4. Olympus TG-820 iHS Top Buttons Replacement, Back Case: Schritt 4, Bild 1 von 1
    • Orient the camera so you are looking at the bottom.
    • Remove the three 3.85mm Phillips #00 screws from the bottom of the camera.
    Frag FixBot
  5. Olympus TG-820 iHS Top Buttons Replacement: Schritt 5, Bild 1 von 1
    • Orient the camera so you are looking at the side plate.
    • Remove the two 3.15mm Phillips #00 screws from the side plate of the camera.
    Frag FixBot
  6. Olympus TG-820 iHS Top Buttons Replacement: Schritt 6, Bild 1 von 2 Olympus TG-820 iHS Top Buttons Replacement: Schritt 6, Bild 2 von 2
    • Orient the camera so you are looking at the front plate.
    • Remove the two 3.8mm with the Phillips H1.5 from the front plate.
    • Remove the "Olympus" plate.
    Frag FixBot
  7. Olympus TG-820 iHS Top Buttons Replacement: Schritt 7, Bild 1 von 1
    • Remove face plate.
    Frag FixBot
  8. Olympus TG-820 iHS Top Buttons Replacement: Schritt 8, Bild 1 von 3 Olympus TG-820 iHS Top Buttons Replacement: Schritt 8, Bild 2 von 3 Olympus TG-820 iHS Top Buttons Replacement: Schritt 8, Bild 3 von 3
    • Locate three small black screws inside of the battery compartment.
    • Remove the 3.85mm Phillips #00 screw on the far left side.
    • Remove the two 5mm Phillips #00 screws on the right side
    Frag FixBot
  9. Olympus TG-820 iHS Top Buttons Replacement: Schritt 9, Bild 1 von 3 Olympus TG-820 iHS Top Buttons Replacement: Schritt 9, Bild 2 von 3 Olympus TG-820 iHS Top Buttons Replacement: Schritt 9, Bild 3 von 3
    • Orient the camera to be look at the top.
    • Remove the 5.4mm Phillips #00 screw on the top left side.
    • Remove the 7.4mm Phillips #00 screw next to the "ON/OFF" label.
    • Pry off top button plate with black nylon spudger.
    Frag FixBot
  10. Olympus TG-820 iHS Top Buttons Replacement: Schritt 10, Bild 1 von 2 Olympus TG-820 iHS Top Buttons Replacement: Schritt 10, Bild 2 von 2
    • Rotate to bottom of camera and locate bottom latch.
    • Wedge black nylon spudger in between bottom latch and camera base to release LCD Screen from camera.
    • Push firmly apart.
    • Some buttons might fall out.
    Frag FixBot
  11. Olympus TG-820 iHS Top Buttons Replacement: Schritt 11, Bild 1 von 3 Olympus TG-820 iHS Top Buttons Replacement: Schritt 11, Bild 2 von 3 Olympus TG-820 iHS Top Buttons Replacement: Schritt 11, Bild 3 von 3
    • Orient the camera to the LCD screen side that is now wedged open.
    • Locate the white ribbon cable and pull out from motherboard.
    • Locate the brown ribbon cable and pull out from motherboard.
    Frag FixBot
  12. Olympus TG-820 iHS Top Buttons Replacement, Top Buttons: Schritt 12, Bild 1 von 3 Olympus TG-820 iHS Top Buttons Replacement, Top Buttons: Schritt 12, Bild 2 von 3 Olympus TG-820 iHS Top Buttons Replacement, Top Buttons: Schritt 12, Bild 3 von 3
    • Remove the two 3mm Phillips #00 screws.
    • Remove the one small black 2mm Phillips #00 screw.
    • Remove silver button plate from camera base.
    • Buttons may come loose
    Frag FixBot
Abschluss
Clemson, Team 7-2, Benson Spring 2016 Mitglied von Clemson, Team 7-2, Benson Spring 2016
CLEM-BENSON-S16S7G2
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 35
Insgesamt: 1,216
