Zum Hauptinhalt wechseln
Einleitung
This guide is helpful if you need to replace an old or bad battery.
  1. Olympus Tough TG-1 Battery Replacement, Battery Removal: Schritt 1, Bild 1 von 1
    • Release both latches on the battery compartment on the bottom of the camera to open the door.
  2. Olympus Tough TG-1 Battery Replacement: Schritt 2, Bild 1 von 1
    • After you have removed the latch, open the compartment door to remove the battery.
    • The batteries contain highly acidic contents. If the battery has leaked or ruptured while inside the compartment, there may be damage to the camera's circuitry. Carefully clean out any residue from the battery using latex gloves and tissues.
    • If the compartment door is loose, check the hinge or the locking pieces under the rubber pad. To do this, unscrew and remove the rubber and metal plate on the door.
Abschluss
USF Tampa, Team 4-6, Brown Winter 2015 Mitglied von USF Tampa, Team 4-6, Brown Winter 2015
USFT-BROWN-W15S4G6
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 7
Insgesamt: 723
