Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Clip Side Repair: Schritt 1, Bild 1 von 2 Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Clip Side Repair: Schritt 1, Bild 2 von 2
    • Remove both 6 mm screws from the clip side of the camera.
    • After you have removed the two screws, remove both the clip and the plate behind the clip so that the inside of the camera is exposed.
    • If one of more of the clips appear to be broken, the back plate might need to be replaced.
  2. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Top of Camera: Schritt 2, Bild 1 von 1
    • The top of the camera does not contain screws. You do not need to remove anything from the top of the camera.
  3. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Plug Side: Schritt 3, Bild 1 von 3 Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Plug Side: Schritt 3, Bild 2 von 3 Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Plug Side: Schritt 3, Bild 3 von 3
    • Remove the two 5 mm screws on the side of the camera with the plug.
    • Open the compartment door and remove both 6 cm screws inside of the compartment door. This will allow you to remove the tan piece held by the screws.
  4. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Bottom: Schritt 4, Bild 1 von 1
    • Turn the camera so that you are looking at the bottom of the camera.
    • Remove the two 4 mm screws from the bottom of the camera.
    • The screws are different. The rear screw is has an unthreaded shank to locate the outer shell while screwing into the inner frame.
  5. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Front Panel: Schritt 5, Bild 1 von 3 Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Front Panel: Schritt 5, Bild 2 von 3 Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Front Panel: Schritt 5, Bild 3 von 3
    • Use the plastic opening tool to remove both components of the front panel. This includes the black part on the outside of the front panel and the main silver panel.
    • Once every screw and panel is removed, you can replace the backplate to make your camera weatherproof again.
  6. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Opening the Internal Case: Schritt 6, Bild 1 von 3 Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Opening the Internal Case: Schritt 6, Bild 2 von 3 Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Opening the Internal Case: Schritt 6, Bild 3 von 3
    • Using the plastic opening tools, carefully open the case.
    • Do not tear the white circuit ribbon.
  7. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Opening the Screen's Protective Cover: Schritt 7, Bild 1 von 3 Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Opening the Screen's Protective Cover: Schritt 7, Bild 2 von 3 Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Opening the Screen's Protective Cover: Schritt 7, Bild 3 von 3
    • Using the screwdriver, remove the ten 3mm anchor screws.
    • Using the plastic opening tool, open the protective cover so that the screen is exposed.
  8. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Unclipping the Screen from the Circuit Ribbon: Schritt 8, Bild 1 von 1
    • Carefully unclip the screen from its circuit ribbon.
  9. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Circuit Board For Back Buttons: Schritt 9, Bild 1 von 1
    • After removing this plastic casing from the screen, the only thing holding the circuit board to the plate is a screw 3 mm in length, with a diameter of 2.5 mm. Remove this screw.
  10. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement: Schritt 10, Bild 1 von 1
    • This is what your device should look like after removing the one screw.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
USF Tampa, Team 4-6, Brown Winter 2015 Mitglied von USF Tampa, Team 4-6, Brown Winter 2015
USFT-BROWN-W15S4G6
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 8
Insgesamt: 717
