Zum Hauptinhalt wechseln
Einleitung
Check to see if the back plate can be placed back onto the camera. Make sure there are an even number of clips on the back plate. If one or more clips seems to be broken, the back plate needs to be replaced.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove both 6 mm screws from the clip side of the camera. After you have removed the two screws, remove both the clip and the plate behind the clip so that the inside of the camera is exposed.
    • Remove both 6 mm screws from the clip side of the camera.
    • After you have removed the two screws, remove both the clip and the plate behind the clip so that the inside of the camera is exposed.
    • If one of more of the clips appear to be broken, the back plate might need to be replaced.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Grant Lee
201 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 4-6, Brown Winter 2015 Mitglied von USF Tampa, Team 4-6, Brown Winter 2015
USFT-BROWN-W15S4G6
4 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 2
Insgesamt: 159
