Einleitung
This guide will teach you how to remove and replace the camera's back plate. This can help you replace the plate if it is broken.
Was du brauchst
Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
Use the plastic opening tools and your fingers to pry the front plate from the camera.
Fast fertig!
Abschluss
