Einleitung
This guide will help you replace your LCD screen.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
Use the plastic opening tools and your fingers to pry the front plate from the camera.
Using the Phillips PH000 screwdriver, remove the 4mm screw from the bottom left corner of the button plate located under the button membrane.
Fast fertig!
Abschluss
