Zum Hauptinhalt wechseln
Omaker M4 Battery Replacement
Was du brauchst
  1. Omaker M4 Battery Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Battery Replacement: Schritt 2, Bild 1 von 2 Omaker M4 Battery Replacement: Schritt 2, Bild 2 von 2
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Battery Replacement: Schritt 3, Bild 1 von 2 Omaker M4 Battery Replacement: Schritt 3, Bild 2 von 2
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Battery Replacement: Schritt 4, Bild 1 von 1
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Battery Replacement: Schritt 5, Bild 1 von 2 Omaker M4 Battery Replacement: Schritt 5, Bild 2 von 2
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Battery Replacement, Battery: Schritt 6, Bild 1 von 3 Omaker M4 Battery Replacement, Battery: Schritt 6, Bild 2 von 3 Omaker M4 Battery Replacement, Battery: Schritt 6, Bild 3 von 3
    • Use the metal spudger to carefully pry along the entire side of the battery from its connecting tape on the back cover.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Carlos Pernia
170 Reputation
1 Anleitung geschrieben
USF Tampa, Team 2-2, Sullivan Spring 2016 Mitglied von USF Tampa, Team 2-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G2
3 Mitglieder
2 Anleitungen geschrieben
Ein Kommentar
What battery is required for this though? Is it easily found on amazon?
Mohsin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 10
Insgesamt: 1,218
