Zum Hauptinhalt wechseln
Omaker M4 Motherboard Replacement
Was du brauchst
  1. Omaker M4 Motherboard Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Motherboard Replacement: Schritt 2, Bild 1 von 2 Omaker M4 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Motherboard Replacement: Schritt 3, Bild 1 von 2 Omaker M4 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Motherboard Replacement: Schritt 5, Bild 1 von 2 Omaker M4 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 2 Omaker M4 Motherboard Replacement, Motherboard: Schritt 6, Bild 2 von 2
    • Remove the mic wire by carefully pulling the plug out of the socket.
  7. Omaker M4 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the speaker wire by carefully pulling the plug out of the socket on the motherboard.
  8. Omaker M4 Motherboard Replacement: Schritt 8, Bild 1 von 2 Omaker M4 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Use Phillips PH00 screwdriver to remove the three screws holding the motherboard in place.
  9. Omaker M4 Motherboard Replacement: Schritt 9, Bild 1 von 2 Omaker M4 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Remove the screws using the screwdriver.
    • Since the screws that hold the motherboard in place are smaller, the screwdriver is able to pick them up.
  10. Omaker M4 Motherboard Replacement: Schritt 10, Bild 1 von 2 Omaker M4 Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Carefully remove the motherboard with your hand by lifting it from the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
[deleted]
679 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,120
